Posts: 17 |
what is the speed limit on the non-svt 2.5 dura?
Posts: 228 |
Allegedly 112 MPH, but I have never made an opportunity to check. -FD
1995 Contour SE V6 5 spd My life is a lot like cold women and warm beer.
Posts: 1,445 |
yup i've been able to verify several times...most recently 2 nites ago....it is a paltry 112
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 494 |
Originally posted by gdub520: yup i've been able to verify several times...most recently 2 nites ago....it is a paltry 112 That must suck! Perhaps the speed is limited more depending on where you live! My little Zetec can pass 120Mph no problem! :p The limiter must be broken or something! Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 803 |
not my z-tec or my d-tec though I wish it did sorpass 112mph/184kph.
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Administrator
Administrator
Posts: 4,527 |
it is usually tire dependant, a manufacturer cannot allow a vehicle to be capable of speeds higher than the factory tire is rated for. Example, the Mustang GT in 99-01 that came originally w/ the 16" wheels had tires rated at 129mph (IIRC) so they were electronically limited to 125mph, where the GTs that came w/ 17" tires had much higher speed rated tires (149+) and they did not have electronic limiters.
It's all about balance.
bcphillips@peoplepc.com
Posts: 785 |
Originally posted by Stephen: Originally posted by gdub520: [b]yup i've been able to verify several times...most recently 2 nites ago....it is a paltry 112 My little Zetec can pass 120Mph no problem! :p The limiter must be broken or something!
Stephen[/b]do you have a chip ?
Red '97 GL Sport MTX IVELISE ================================== "Let every nation know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe to assure the survival and success of liberty." John F. Kennedy
Posts: 494 |
Originally posted by carrot_top: Originally posted by Stephen: [b] Originally posted by gdub520: [b]yup i've been able to verify several times...most recently 2 nites ago....it is a paltry 112 My little Zetec can pass 120Mph no problem! :p The limiter must be broken or something! Stephen[/b] do you have a chip ?[/b]I looked and did not see any chip! On an older post someone showed a pic of what the "super chip" looks like when installed and I saw no such thing there! I've only hit what I think was the rev limiter once just after I bought the car but since then it has not stopped me! It may have been because I turned off the OD while racing, to try and get the advantage of higher rpm's! :rolleyes: I learned my lesson real quick!  It did not help me in the least! :p Perhaps there are internal mods that the prior owner has done! I'm not sure if the computer can be reprogramed for better performance. Stephen
Posts: 1,701 |
Originally posted by Stephen: My little Zetec can pass 120Mph no problem! :p The limiter must be broken or something!
StephenI gotta see this!!!
Nick 2000 Malibu LS Mods: K&N, Jet-PCM Lowered with Eibach's and on 18's,Clear Sidemarkers,Tinted all around, badgeless Retired Vehicles: 98 Contour
Posts: 494 |
Originally posted by Saturn_k1: Originally posted by Stephen: [b] My little Zetec can pass 120Mph no problem! :p The limiter must be broken or something! Stephen I gotta see this!!![/b]If I can find someone that would take the picture while going over 120mph, I will post it here! Trust me, if you want proof, wait till the snow melts and I will get a photo of it. I would prefer to film my tour but my video camera is not a digital type so that I could transfer the video to my computer! Let me remind everyone, it will take me alot longer to get to 120mph than the V6 but at least I can do it fairly quickly! :p Stephen
