Posts: 12 |
I'll check the measurements for the 510s. But how much are they and where do i get them if I choose to go with those? Are you guys w/bubble problms saying that the lights lens itself bubbles? How does this affect the light, car, and wiring?
1998 Contour LX It's Getting There! No Money, Mo Problems!
Posts: 184 |
bubbling here too...2 times to be exact...damn 885's....but they were bright...i dont even use the foggers anymore....
Chris
99 V6 Sport/Silver
SVT kit~SVT Dual Ex.~KKM intake~Front & Rear grills painted silver~GTS Headlight covers~Plasma Blue light under dash(removed white bulb)~30 % tints~Tinted Rear Reflector~Wood Grain Kit~Removed door dings~Super White Heads~Plasma blue reverse lights~ blacked out sail panels~painted brakes Blue~complete stereo system~
Posts: 570 |
Brian, PIAA 1100 series fit like a glove!!!
Andy V. 99 SE Sport SGTO KKM,No Res,Dual exh. 17" Cellos-225/45/17 Sumitomos vannanthony@hotmail.com Semper Fidelis
Posts: 3,934 |
Originally posted by Roger R: Did you try the #885 foglight mod Umm, Brian got his fog/driving lights from Big Lots. The cheap ones I got from Checker, (my boss gave them to me as a going away present, from Checker) suck. They add only extreme foreground illumination, so much so that you can't see it from the driver's seat. They haven't beem turned on in months. :rolleyes: I am going to see if my friend will warranty them for me toward some better ones. Brian, if you get a little creative, the holes do flare slightly when the exit the car. If the 510's are larger then the stock holes you might be able to do some trimming and then extend the bracket. Only problem to this is they would need to go with the car if you ever sell it, as you would no longer to put those fake vents back in.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 767 |
I have the 50w 885 fogs and I am getting a bit scared about this bubbling talk...
If I went with 50w 893's would that be better? Or should I just stick with 38W 893's?
1998 E0 Ford Contour SVT Built on 8/19/97 -- #3101/6535 Silver Frost/Midnight Blue * New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
Posts: 105 |
I know you said you didn't want to go the cheap route but I bought a pair of driving lights for my 98 Mystique a year ago from Alpinetech ( www.alpinetech.com) for around $27/pr. They are 55W/H3 and have a glass lens (no bubbles). Except for a bulb that burnt out recently they have worked fine. The DC260 model fits my stock location nicely. They sell various shapes and sizes that will probably work on a Contour as well. Jeff
Posts: 3,223 |
I've had the 885 for a while and yes they will eventually bubble the lenses! -Andy
Posts: 770 |
To answer your question:
Most folks here have used the PIAA 510s. They are a direct size match for our lens size, and they seem to work reasonably well.
I have installed the 510 fog lights in my SVT and I have the following feedback...they work "OK" for a fog light, but my old $75.00 Hella Halogens were like 3x as bright (and 3x as big!).
I have had the distinct misfortune of having BOTH of my lenses crack, one of which happend while washing the car while the fogs were on. Shame on me for spraying a hot lens with cold water, but I wonder if the second one did not crack while driving through an icy puddle. I will be calling PIAA shortly to see what they can do for me.
For installation on the PIAAs, you should do a lot of searching on here. I had a great thread of replies when I looked for install info about 3 months ago.
Lastly, I bought mine for $188.00 from an online vendor that I can't recall...search thru Google, you can find plenty of them.
Good Luck...
Andrew 99 SVT
Posts: 1,367 |
piaa is a good choice, no problems yet and they are super bright. i even got the matching 9006 piaa's because they made my stock headlamps look yellow! u can pick the piaa's up from www.groupbuycenter.com relatively cheap. well, cheaper than spmotorsports, and most other online vendors. i got my 510s from a group buy here a while back. iirc i paid like 160 for them.
Posts: 1,537 |
The PIAA 510 will work with the SVT and the SE Sport. Both cars us the same OEM fog lamps. When I got them on last year's Group Buy, they were $155.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
