Page 2 of 2 1 2
#37885 01/16/02 04:25 PM
O
ohyeah Offline OP
O
[QUOTE]Originally posted by jcboeckl:
Say your going to start at the left and work towards the right. Instead of pulling towards the right pull the opposite direction lightly
Are you talking about the gaurd itself or the sticky glue underneth the gaurd? Do I pull the gaurd in the opposite direction?
99 SE
KKM
K&n air
BNM gauges
CAT Exhaust
#37886 01/16/02 04:46 PM
based on pollo_loco69's no clear coat, and the fact that our cars are only like 500 cars apart in build year, came from the same factory and are the same colour, i am reluctant to do this mod too....
but im gonna go for it, if theres no clear coat, what the hell.....it'll match the poorly matched paint where my stock antenna hole was filled....
laugh
1999 Contour SE comfort package zeeeetec VCT, that light blue colour
Mods:
*Sony Mobile ES Deck, MTX Subs, Precision Power Amp, Boss tweeets
*Mondeo Antenna Mod, stock antenna hole filled and shaved
*Tinted glass
*Lower bumper grille custom (wow took me nearly all afternoon)
*KKM intake, platinum plugs, full Mobil-1 Synthetic oil conversion
*zetec badging
Future:
*Clear corners/blue turn signal lamps (when i get the testicular fortitude)
*exhaust/rims (when i get the money)
*sidemarkers/remove door dings (when it gets warm outside again)
#37887 01/16/02 05:01 PM
O
ohyeah Offline OP
O
ok guys
Its seems that most of the problems with the results of this mod is from having bad paint jobs from the factory.
My paint is flawless, i guess ford had a good day when they made mine.
Given all the info should i go for it or not???????
99 SE
KKM
K&n air
BNM gauges
CAT Exhaust
#37888 01/16/02 05:19 PM
KJ Offline
Ohyeah ... best thing to do (I think) is pull on one side and check before going through it. You can always buy them and re-apply if needed.
As for getting them off I used an old shirt and my thumb. No blistering at all. I rubbed the tack from the back of the car towards the front (kinda just rolls). You'll have to see what works best for you though. Just keep trying different things laugh
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
#37889 01/16/02 05:54 PM
BP Offline
As for removing the gunk, bug and tar remover will work as well if you still have some remaining glue on the car and don't want to rub your finger off.
I used it to remove the same mess left when I removed the 24v badges on the car.
-Brian-
98 SE DTec MTX
#37890 01/29/02 06:27 AM
Sorry for the late reply, but I was referring to the sticky glue underneath.
It came off very easily if you pulled the opposite direction your are peeling it in.
Hope that helps if you haven't already done them smile
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
Page 2 of 2 1 2
