I've studied the pics of the SP Motorsports battery relocation kit and there's one part of this project that I am wondering about. What happens with the wires and connections under the hood that used to connect to the battery? Anyone have any closeup pics of what you did under the hood? The SP Motorsports kit looks like it just has some clamps and connectors that deal with the trunk side of the relocation. Thanks.
Jeff
You need to but a remote insulated battery terminal. Moroso makes them and you can get them form Summit Racing. Just call the Tech Line and tell them what you want they'll find the part number. I can't rememeber it myself. But it's what I used and it works great.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Stazi is this a good mod to do? Dave (gr8ride) said it provided much more cold air to the engine (I belive Dave, J/w what you thought)
Joe
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
That's part of the reason I'm thinking about moving mine. Also, there's not enough room for the heat shield I'd like to add since the KKM filter is already pressed against the battery and then you still have the wires, etc., to deal with.
I still wish someone would post a few close-up pics of their finished product under the hood.
Jeff
I
I
Could someone with the spmotorsports battery relocation kit please post some pictures for us, thanks.
98 Contour LX V6 Mtx
KJ Offline
I wouldn't do the SP Motorsports batter relo. Andy W. and I got the kits from Summit (basically the same) and were not impressed with them at all). I would do the Optima battery (sealed unit), battery tray, and J-bolt hold downs. As far as the wires in the engine bay go, get a distribution block from a radio install shop and runs the wires into it. Just my .02
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
I did my own kit for about $70. I picked up some 0 gauge cable, 200amp fuse, 150amp circuit breaker, and some wire covering. I love the extra room for my SCA cold air intake. Much easier to work in the engine bay.
The battery has since had a box built over it:
http://www.fastcougar.com/forums/attachments/trunkresize2%2Ejpg
I rigged up a bracket for the Jacobs ignition you see in the pic.
http://www.fastcougar.com/forums/attachments/photos2%2Ejpg
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed:
svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
looks good, but ideally shouldn't the bat be on the passenger side? so that you can slightly offset rather than augment the weight of the driver?
97 Zetec MTX Sport
Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam)
Dual Fiamm air horns
Mk1 Mondeo Clear corners(and yes I made them fit....)
Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com
AIM: AphexTwinGrin
