Originally posted by Escort1991:
Drum, one question: I hooked it up to the #56 wire for the PCM, but it redlines at 4500. Is there a way to fix it and recalibrate it so it redlines where it is suppose to?
Well, I can't really say. All I can guess is that there might be a difference between your OBD-I PCM, and my OBD-II. Some have said that there is a resistor on the back of the cluster than can be changed to "recalibrate" the tach. But noone has specified which (if any) resistor it is, and to what Ohm value it needs to be changed to.
Andrew Morris
\'99 SE Zetec ATX
All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
