Posts: 816 |
2 e-rams make more power as is dyno proven on engines, especialy bigger ones(5L and above), so it goes to reason that two on a smaller engine will help even more. I plan on doing exhaust also, and one day a turbo. I want the most from the engine and the e-rams can be used with a turbo as well as an upgraded exhaust, so why not do it all? I plan on spending more than $300 on my car to make it fast, so it's not like I have to pick what I want to do.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 139 |
Then giddyup boy!!!!
99 SE Zetec ATX CTA intake ZX2 FMS wires(that don't fit my oddball coil) andenthal@mindspring.com
Posts: 1,075 |
Originally posted by Paul Kienitz: Originally posted by D Davis: [b]With the CAI, I think you'd be pulling more air w/out the e-ram than with. It looks to me like that thing is quite a spacehog inside that pipe. Also, if the air velocity in the CAI is xx and the maximum air velocity the e-ram can generate (yy) is less than xx, all you're doing is lowering air velocity and lowering total air volume. I think you underestimate the e-RAM. The amount of air it will move through an open-ended pipe is around three times the Zetec's maximum consumption. If there were a way to fit it into your intake, I bet it would give you gains.[/b]Moving air doesn't matter if it doesn't pressurize.
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 378 |
If you are going to get a 200+HP turbo kit for SURE, do us all a favor and forget the eRam. BTW you'll want 2.5" piping then not 2.25"...
Posts: 620 |
Originally posted by T-red2000se: Moving air doesn't matter if it doesn't pressurize. What do you think moves the air, if not pressure? Harry Potter's magic wand?
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 1,075 |
I can wave a piece of paper and move air. Certainly not enough to put a charge into your intake. The e-ram only puts out a hair under 1psi. That's not a lot. Enough to notice a bit? sure. All I'm saying is don't judge the thing by how many CFM it puts out.
Posts: 491 |
CFM does NOT = PSI. They are two different types of measurement.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
