Posts: 816 |
I know the e-ram will give me added HP, but can i get the super e-ram(2 units) and expect even more gains??? E-Ram is the site
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 3,950 |
I would go with intake and exhaust first before this. It looks like you are seriously considering this. Good luck. I really don't think it is worth it for the money. But that is just me.
Posts: 816 |
i plan on e-ram and intake and exhaust,, exhaust b4 to handle it all.... gotta get some sleep good nite
Posts: 491 |
Eram is definately after intake and exhaust. The Eram isn't the best Hp to $ ratio, but it still will give some decent gains. (~7 HP in a 96 Honda with Intake, Exhaust, and Header). I will be getting one myself after I get my TB optimized. Every HP counts on a 4 cylinder.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 816 |
So, anybody know if I could effectively use 2 e-rams (super e-ram) in DDavis's intake? I also want to use aem bypass valve in the intake. I'm asking bout 2 because 2 are required to show 4-6% gains in bigger engines, so it seems 2 would show bigger gains in smaller engines.
Posts: 30 |
you could use two, but you would have to get a y pipe and mount one e-ram on each end of y. If you just put two in line you will not gain much more than just having one. The second would only add half the hp of original. If you ad Y you will get twice the air folw and twice the pressure (pressure+more air=more hp).
Have fun, but it seams high priced to me for only 15 hp, my drop in K&N filter added 8+ hp
Posts: 816 |
Originally posted by Fastzetec2.0: you could use two, but you would have to get a y pipe and mount one e-ram on each end of y. If you just put two in line you will not gain much more than just having one. The second would only add half the hp of original. If you ad Y you will get twice the air folw and twice the pressure (pressure+more air=more hp).
Have fun, but it seams high priced to me for only 15 hp, my drop in K&N filter added 8+ hp Do you have dyno sheet of your K&N? Drop ins normally don't add more than 5hp. I'm not quite trusting you on the y-pipe, since nobody with dual e-rams had used a y-pipe.
Posts: 30 |
the y pipe thing is simple Physics think about if you have two points of air pressure pushing into one hole 100% of the air from each intake gets in, if you have one e-ram pushing on the other the you only get 3/4 of the potential pressure.
Hope this halps you understand, an if you still are not confident in me then ask more people.
I still think that if you save your money a little longer and buy a turbo from performancefords.com or even a vortec super charger you will get more bang for your buck, but buy what makes you happy not what makes me happy.
Posts: 1,075 |
According to E-ram ( www.electricsupercharger.com )they are in-line, not in a Y-configuration. You should E-mail them and set them straight.
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 1,692 |
Originally posted by Fastzetec2.0: Have fun, but it seams high priced to me for only 15 hp, my drop in K&N filter added 8+ hp drop in K&N doesn't even add 2hp SORRY.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
