todras Offline OP
I did search but I couldn't come up with answers. I guess early style Zetec Contour's have a different setup for the w/p than the 98+. Has anyone done a 97 and can give me any pointers.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
Lee Offline
Well I haven't done it myself but my mechanic said he would never ever do it again.
Lee Cox
In life begins responsability...
Project Car
todras Offline OP
Lee you aren't very inspiring. frown I'm trying to help another CEGer in my area that PM'd me. It was easy on my V6 and I guess the early Zetecs aren't as difficult as later models. Still sound more lika a PITA than my V6. Wish I had my manuals at work.
Lee Offline
You have to remove the Sepentine Belt, The Timing cover and the timing belt to get to it. I'm not sure if the Crank Pluuey has to come off or not. It is a major job. You may also want to look at doing the Timing belt while it's off. I started to do it. Then desided this would be better suited to someone who knows alot more about cars. I believe all year models of Zetec are the same in this respect.
Lee Cox
Project Car
to get the the water pump on a pre 98 you need to remove the timing belt. The water pump is behind the covers. This means you need to remove the upper motor mount, the one that looks like a C and support the engine. make sure you index the cams as they will move a bit but not to much. Also make sure you get the one time use spring to retension the timing belt tensioner. I would check for bad pullies and replace anything that looks poor when it comes out. Make sure to loosen the water pump pully first before taking the accessory belt off. in all you have to take the same steps you would take to replace the timing belt but add the water pump to it. Hope that helps
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side
Father - 1995 Contour SE Duratec 5-spd
Mother - 1999 Contour SE Sport Duratec 5-spd
My CEG Registry
My Car
My Home Page
todras Offline OP
Thanks! I think I'm going to hand this job to someone that's more qualified than myself.
Z
Z
you wanna send them to my house when they get done with that one cause mine is heading south I think.
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
E
E
I did mine. Took me 6 hours and 15 minutes. That counts running to the parts store for the pump, and dinner time. smile
MAKE SURE YOU HAVE AN 18MM SOCKET!!!
Its not the most difficult, just time consuming because of what all needs to come off. The coolant tank, the p/s pump, the engine support, the passenger side motor mount, the little clip that holds the p/s pressure hose, the exhaust manifolt heat shield, all three timing belt covers, the timing belt, the crankshaft pulley, the w/p pulley, the serp belt, the timing belt, the valve cover, and you need to disconnect the lower radiator hose.
I think that covers everything. smile
Drop me a pm or IM me. Exdelayed on AIM and Yahoo, 25511759 on ICQ. smile
BTW, I dropped under $90 for all the parts, new coolant, and new p/s fluid (I accidentally dumped mine).
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
Looks like I will be doing mine soon. I'm getting up there in miles and it is only going to cost me about $50 for the belt and the W/P and a days worth of work. laugh
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
