Posts: 1,244 |
Different shift points and curves. But i think a chip should just adjust that.
This is wierd. I was just talking about this to fellow CEGers here in MN. In the next couple of years I plan to strip down the car, rebuild it and use it as a personal squad car(when I get out of college). I plan to run the SVTF engine and trans. Being the aftermarket is huge for these cars I should be able to find some nice parts for it, since i will be transfering engine and tranny and of course PCM.
Posts: 1,692 |
Originally posted by OhSigmaChi: Joe,
You already have an MTX why would you need a PCM to switch from one MTX to another? 6 forward gears 1 reverse.....
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 3,950 |
Originally posted by ZetecRacing: Originally posted by Andy W.: [b]The Getrag can't handle more than 200hp at the crank so you are better off with a beefed up MTX-75.
-Andy it can always be beefed up too you know
OOH and hector get me a PCM that would work with MY motor and the 6 speed and we will get to work on it I'll be the doner car [/b]If I get you that then you get me a supercharger and I will be the donor car.
Posts: 282 |
It would be so nice to have the 6speed. I wunder how much the PCM would cost. It would be sweet. ....Brad
Aviation Electronic Tech's RULE!! Your born you die inbetween you work on cars how can we be so lucky. 99'Mystique Zetec VCT ATX "CEG" on front and back windows. 10 inch HED series Cerwin-Vega My ther car is a 1996 4Runner Sunfire red pearl with Bilstein shocks, K&N air filter and Xenon fender flairs "There is always room for more mods"
Posts: 1,559 |
One thing about the PCM though It's calibrated to the SVT Engine and not a 130HP stock engine. You'd have an easier time swaping in the whole SVT drivetrain.
Posts: 3,934 |
SVTF engine and the six-speed. I could see a few Zetec'ers hunting SVT `tours!
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 650 |
I still dont see the need to switch PCMs when swithing manual trannies from a five speed to a 6 speed. Case in point: My brother owner of a 1995 Mustang Cobra 5.0 switch from the stock T-5, to a Dodge Viper six speed with no modification to the PCM, the PCM doesn't know what gear your in, it only knows load, RPM, and Speed(yes, I know it monitors tons more than that, but I'm breakin' it down kindergarten style here), it doesn't give a crap about gear ratio(which is all you are doing by adding a 6th gear: redistributing the gear ratios).
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 1,692 |
a 95 mustang is also OBDI where me and alot of others are OBDII and there are alot more sensors and what not in them... I know of a chicago CEGer who tripped a CEL which was a tranny code just hours before his MTX went bye bye...
Posts: 650 |
If you've ever removed your MTX-75(I installed my own Quaife, clutch, and axle shafts; so I have some experience here), you'll see there are a few sensors ,but I don't see anything that would make the PCM care whether or not you have 5 or 6 forward gears. The biggest problem I can see is, does anyone know whether the bellhousing and engine castings from the FSVT are the same as the Contour? plus the need for a heavily modified subframe, and custom axle shafts.
