Page 2 of 2 1 2
make sure you try a mom and pop hardware store, cause you wont find reverse thread metric in your big box stores like home depot and lowes.....my ace hardware has mroe nuts and bolts than both of those stores and we cant even get left hand metric stuff.....go figure.....
-chris-
96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Vice grips and WD-40. wink
Have fun the intake makes a world of difference. cool
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
F
F
go to pep Boys, auto Zone, advanced Auto Parts, SEARS, or another hardware store and look for screw removers (not the flat black ones!!!) they have a square end and have a tapered spiral end that looks sorta like a masonry drill bit.
hope this helps, reversed threads are hard to find unless you go to a hardware store thats specialty is fuels.
Originally posted by Pollo_loco69:
I couldn't get either one out. frown I need some help people. laugh
Just grab the shaft with a Vise-Grip and unscrew it. It was easy on mine. The best grip would be on the wide spot just below the upper threads.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Hack-saw. :rolleyes: :rolleyes: Watch out for metal shavings, but it takes about 5 minutes.
99 SE Zetec ATX
CTA intake
ZX2 FMS wires(that don't fit my oddball coil)
andenthal@mindspring.com
I was thinking dremel. laugh
-Colter
My Car
I took the two nuts tightened them together by going opposite directions on the same stud, then used an open ended wrench on the bottom nut. Took a little muscle power, but it came off. Vise grips kept slipping off on me.
BLUE-1999 Contour SE-Zetec-Clear Corner Lights-Nokya 3157 corner bulbs-Kenwood Exelon X815-2-12" Pioneers-4 6x8 3-way pioneers-Cuzo 9006's & 9005's-Glowing Ford Emblem On Decklid-Blue Interior lights-Alarm W/ Remote Starter-
Daytime Running Lights-CTA Intake-Winshiel Nozzle Lights-Audi A6 Side Marker Lights-Mesh Grilles (Good Ole Gutter Guard)-Just Added SVT Exaust
Thanks For The Idea CEG'ers !!!
Page 2 of 2 1 2
