Q
Q
i got a cold air intake for my car, but it makes it idle too low and it dies. it is also a lot slower than before, i think it is making too lean of an air/fuel mixture. is it possible to use a cold air intake without modifying the computer? i have also tried resetting it by taking out fuses 4 and 11 for a couple minutes, but no such luck. any suggestions?
you could try disconnecting the negative battery cable for 20 minutes instead of yankin out the fuses. Also, if you have a 2000 i would suggest doing the IAT mod. If you don't know what it is type it in the search. DDavis helped me do it to my car.
2000 Contour SE ATX Zetec
Mods- smile
AIM: CZboyovski
SVT exhaust
Z\'s Contour
Q
Q
i searched for it in every forum, looked in the faq's and had no luck in finding out what it is. can you tell me what the IAT mod is?
Z
Z
after you pulled the fuses did you let the car run at idle for 10 minutes to relearn idle?
the IAT mod is where you put a resistor on it some people have had improvements doing this others have had problems after doing it. search the performance section with my member number I posted a like to a ZX2 site that had the how to for it.
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
Z
Z
here not as LAZY as I thought I was....
clicky clicky
Joe Hartley
AIM: ZetecRacing
My Site My Profile
2000s had the IAT? confused IIRC Isn't this on the intake? I am just asking because I had nothing plugged into my intake. confused
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Z
Z
Originally posted by LoCo:
[b]you could try disconnecting the negative battery cable for 20 minutes instead of yankin out the fuses. Also, if you have a 2000 i would suggest doing the IAT mod. If you don't know what it is type it in the search. DDavis helped me do it to my car.
2000s had the IAT? confused IIRC Isn't this on the intake? I am just asking because I had nothing plugged into my intake. confused [/b]
yes you do but it is apart of your MAF rather than a seperate piece.
Joe Hartley
AIM: ZetecRacing
My Site My Profile
Isn't that why the MAF's went to a six wire setup instead of four? Most of our MAFs had four wires, the IAT is two wires. Makes sense to me. laugh
My experience is that the engine will idle weakly for the first few days after getting a performance intake, and what you need to do is NOT reset the computer, but give it time to learn the new characteristics. Once some time passes, the problem you describe will be a temporary phase you have to go through any time the computer gets reset.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
9
9
Would the IAT mod apply to a 96 mystique as well??
