Posts: 1,075 |
This was on private property, NOT street racing, so I hope this doesn't get locked... Anyways, 2001 Civic EX with true cold air, cat-back, and headers, Manual... It was no contest. By 20 feet I could see his tail lights, and that's with me getting a better jump. I did begin to pull on him down the stretch, but by then it was far too late. I understand that with my ATX i am not going to be as quick, but damn! This is embarrasing! BTW, we traded cars, and got the same result.
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 1,559 |
With an ATX it's understandable.
He had more mods, less drivetrain loss, and a lighter car. Don't feel bad. :-)
Posts: 3,950 |
It is a manual and it is lighter. Your stock Hp is about the same as his 130 to 127 for the Civic. And he had some mods. ATX blows balls anyway.
Posts: 1,075 |
I know...I know...just so sad...Oh well, give me a mile of twisties and I may have him, though! :p
Posts: 620 |
Originally posted by T-red2000se: I know...I know...just so sad... Sounds like you need a chip.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 1,075 |
Pennies are already gathering in the jar for the mass exodus to superchip land.
Posts: 378 |
Originally posted by Paul Kienitz: Sounds like you need a chip. Or a MTX-75, flywheel, clutch, cables, shifter, clutch master cylinder and pedal, engine wiring harness, PCM, front sub-frame, some roll restrictors, and a tranny mount.
Posts: 3,950 |
Originally posted by T-red2000se: Pennies are already gathering in the jar for the mass exodus to superchip land. You're going to need more than pennies. :p It makes a big difference though.
Posts: 101 |
u dont need supership all you need is this little baby  hope this helps
1996 Champagne GL 4-banger (ATX) (I miss you baby) AIM:DJT81185 Replaced with 1998 Neon Coupe DOHC 5-Speed R/T 1.084 60' 2.549 330' 7.112 1/8 10.872 MPH 65.15 1000' 14.111 1/4 16.825 MPH 83.12
Posts: 101 |
i dont think my pic worked so go to nopionline and pick yourself up a nitrous exress kit
