Posts: 45 |
I saw a post a little while ago (think it was Redcon96I4) re. the switchable transmission in some ATX's. So I set about looking for some more answers. Haynes manual states that the switch is in the shift panel of the center console, so I looked under to see if there were any extra wires.... (I was hoping that all wiring was the same, regardless of what options and trim!) Well after some knuckle scraping retreiving a screw I dropped into the shift assembly, it turns out that I did not find any extra wires for a dual mode auto tranny  But it was fun all the same. Did Ford put this on any Contiques in North America? Is the CD4E modable other than with a chip?
David BC
White '96 Mystique GS ATX - A work in progress! White '88 Cherokee - still going places!
Posts: 816 |
I believe the consensus is that it's only in Europe.(Why do they get the good crap?, we're better) Only other mod I know to CD4E is to rebuild with performance kit from Level Ten or another company(isn't there another company?) It gives more power, handles more power, and shifts better. You can also paint the shifter and the actual transmission. You can put stickers on the shifter,etc.... ....
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 45 |
Originally posted by Redcon96I4: You can also paint the shifter and the actual transmission. You can put stickers on the shifter,etc.... .... LOL!
David BC
Posts: 3,950 |
For us in the US sport mode=o/d off
Posts: 494 |
Originally posted by LoCo: For us in the US sport mode=o/d off Ah yes, but for me, I don't have a tach and will not know how high the rpm's are until it's too late! If I leave the OD off, won't the rev limiter cut off the power sooner, causing no real benefit at the top end? Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 1,969 |
OD is great for merging onto highways and where you know you won't be sustaining speeds in the 70mph range for a period of time.
The ATX is this car has such a tall 4th gear that you will loose a lot of torque (but gain MPG) when that thing upshifts to 4th at 50 mph :rolleyes:
Kharma is very real and she is one mean b!tch.
Posts: 378 |
I'm under the impression that you can get a new valve body (though prolly more expensive) despite not having the wires. But I'm almost positive that would add stress on the transmission.
Posts: 3,950 |
Originally posted by Stephen: Originally posted by LoCo: [b]For us in the US sport mode=o/d off Ah yes, but for me, I don't have a tach and will not know how high the rpm's are until it's too late!
Stephen[/b]But it is going to have a benefit because most of the Zetecs power is on the top end. You leave the OD on, the car is going to shift into 4th before you hit the limiter. W/O the limiter (w/chip) you can pull pretty hard with the OD off.
Posts: 339 |
Ok im sorry i have been following this post and im stil kinda confused, i have a chip so how does this effect the od?? When it is off (it lights up green on the insturment panel right??) the car is going to be quicker or not??? or is it quicker when the OD is on??? sorry if im confused and it has been cleared up in the posts before but im not seeing it... thanks Matt
'97 Pumice Zetec Sport- Superchip/Apexi DTM Tip/KKM/blue lights/removed door dings/De-Badged/ford racing 9mm-blue/Custom Interior/indiglo gauges Audio -3 JL Audio 10s/-2 kenwoods amps/-JVC cd head unit (with 12 disc changer)/-6x8 pioneers http://www.geocities.com/mattbchillin
Posts: 3,950 |
Originally posted by MB: Ok im sorry i have been following this post and im stil kinda confused, i have a chip so how does this effect the od?? When it is off (it lights up green on the insturment panel right??) the car is going to be quicker or not??? or is it quicker when the OD is on??? sorry if im confused and it has been cleared up in the posts before but im not seeing it...
thanks MattIt will be quicker at highway speeds because when the O/D is on the computer is quick to shift into 4th gear for fuel economy. With the O/D off, the computer doesn't have that option so it stays in 3rd, which means you're at a higher RPM. All the Zetecs power is at the higher RPMs. For example, on my dyno I made my peak power at 5800 RPM and my peak torque at 5600 RPM.  But it is the same on the street. Step on the gas off a light and see how quick it shifts into 4th with the OD off. All you have to do is let go of the gas a hair and it will shift.
