Something went wrong with that url, the end got cut off.
Here is the correct one. There are two addenda that need to be made to that post. One is that the heat shield as pictured there isn't quite complete: it needs a small second piece jammed between the fusebox and the front wall. The second is that, since it's flimsy, after six months of wear and tear it doesn't fit too snugly any more and needs some tape to reduce leakage around all the edges.
But when I install the e-RAM it might get all mangled so I'll wait till then to fix it up... I may need to make a whole new one after the e-RAM is in.
