Originally posted by zetechfun:
heres your proof go to B&M's site look under products transmission kits select ford,lincoln mecruy and there you will find a kit for a 92-95 AODE/4R70W and that my friends is our transimission in our mystique and countours. and before being called a liar again i would apreciate the common ciurtsey of cheking for your own damn self.
Well, since i work for Ford, I did did check for myself. And the AOD-E/4R70W is a
REAR WHEEL DRIVE TRANSMISSION made for the Mustang among others. So, I am not calling you a liar, because B&M does indeed make that kit, But I am calling you misinformed, because there is no way you have that tranny. Either that or you own the world's only 2.oL Rear drive Mystique. :rolleyes:
So, again I suggest that you investigate more clearly before you post. And I will again ask that you try to work on your grammar....I know you don't have a major in English, but I assume you passed fifth grade.....of course if you can't tell the difference between a FWD Trans-axle and a RWD Tranny... :rolleyes:
