Posts: 77 |
what does the overdrive do and should i have it turned off or turned on
Posts: 494 |
Originally posted by joethesajin: what does the overdrive do and should i have it turned off or turned on Overdrive is a highway gear that will lower rpms and increase mph while cruising the highway! Some people leave it turned on all the time, city/hwy, but I turn it off in the city and on on the highway. I find that I get better response in the city if it is off! Really it is up to you! Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 125 |
with overdrive off, third gear is the highest it will do, i wouldn't leave it off all the time, it will suck up your gas!
2000 Contour SE ATX Zetec Mods-  AIM: CZboyovski SVT exhaust Z\'s Contour
Posts: 569 |
It's just a gas saving gear, The car will be more responsive and quicker when off.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 1,969 |
Originally posted by Luckie13: It's just a gas saving gear, The car will be more responsive and quicker when off. And pulling 5500 rpm at 75mph :rolleyes: If you like cars with only a 3 speed, why not buy a 1994 cavalier?
Kharma is very real and she is one mean b!tch.
Posts: 569 |
Originally posted by redhawk: Originally posted by Luckie13: [b]It's just a gas saving gear, The car will be more responsive and quicker when off. And pulling 5500 rpm at 75mph :rolleyes:
If you like cars with only a 3 speed, why not buy a 1994 cavalier?[/b]Huh what the hell are you talking about
Posts: 1,969 |
Posts: 620 |
Leave it on 98% of the time, and turn it off only when you specifically want to rev high, such as either in a sprint, or on a long descent where you want to save your brakes. (On a steep windy descent, you can help your brakes a lot by putting it in 2.)
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 569 |
Well I assumed the guy knows not to cruise down the highway at 75, but if I was racing and shifting some what manually. Thats right about where I'd click the O/D button.
Posts: 3,950 |
The Zetec is fun with the O/D off on the highway...and a Superchip.
