You also have to remove the 2 brass colored bolts ont he cam gear sideof the ehad that are between the camgears. This allows the VCT solenoid to swing up so you can take the cam out of the head. Before you do that, remove the VCT cam gear if you are changing cams. Its much harder to take off when its out of the car.
'00 ZX2 S/R 15.116@89.42 MPH 131 HP@5800 RPM 121 TQ@5400 RPM Winner of the NIRA/B.F. Goodrich Springnationals Max Power class #6 Comp4 Qualifier NIRA Fall nationals AFX UDP, FZRusting Header, and Adjustable Cam gears. Click Here for a discount performance parts. This ain't your little sister's escort, but I'll gladly escort your little sister.
