Page 2 of 3 1 2 3
REMUS makes a header for the zetec as well as an exhaust system. It is however muy expensivo!
96 GL ZETEC MTX
00 MAZDA MILLENIA S
Rogers Dead Pedal
Blaupunkdt Houston
Originally posted by LoCoZetec2.HO:
I thought this issue has been addressed: that the Focus headers would not fit the Contour. confused
Where is the lack of fit? On the top? The front (like, radiator too close)? Bottom (cat)?
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Z
Z
Originally posted by Paul Kienitz:
[b]I thought this issue has been addressed: that the Focus headers would not fit the Contour. confused
Where is the lack of fit? On the top? The front (like, radiator too close)? Bottom (cat)?[/b]
OK it was me that mentioned the fitting problem not hector so I will answer it... yes clearence between the headers and the radiator. a guy I work with has a 2000 ZX3 and I measured the clearence and they have a good 3" more than we do
and you will also need to relocate the cat too but that really isn't a problem to do...
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
Originally posted by ZetecRacing:
[b]
and you will also need to relocate the cat too but that really isn't a problem to do...[/b]
Yeah what he said. laugh So who's going to be the first to try this? I guess I will. wink
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Except that it's highly illegal.......if you get caught. wink
Given the shape of the header it is intended to keep the cat in the stock location, yes? Why would it need to be moved?
And yes, install would be a Bitch!!
Z
Z
Originally posted by SQPlus:
[b]you will also need to relocate the cat too but that really isn't a problem to do...
And yes, install would be a Bitch!![/b]
Illeagel not if the shop that does it fills out the correct papers when they do it... just as to replace the cat even if it is in the same location they have to fill out papers stating why it was replaced...
I have NEVER seen a focus with those headers with a cat in the factory location if they have one at all it has been moved to under the car.
Joe Hartley
AIM: ZetecRacing
My Site My Profile
Either way you need a cat. mad laugh
Hector
Mods...I got em'
My profile
Interesting...I haven't had much luck finding a shop that will move the cat from the stock location. I wonder why the Focii move the cat with that header. confused
The Foci dont move the cat. Focus has a 3 bolt flange on the cat we have a 4 bolt flange. Dont no if its been mentioned b4 but the stock focus header is a tube header that would have to be a huge improvement over our stock manifold. Should be quite a few take offs kicking around.
'69 Chevelle SS
'99 Mystaque GS
B4 y'all jump my case about ? if nothing else it would be a cheap way to figure out what is needed to make any of the focus headers work. adapters or whatever. BTW focus cat from ford is about $600
not cheap
'69 Chevelle SS
'99 Mystaque GS
Page 2 of 3 1 2 3
