Posts: 35 |
ok....i've got a problem and i was wondering what could be causing this.... my car runs fine when i am accelerating, crusing around or whatever, but when i am stopped at a light or stopped in a parking spot, my car cuts off. it's almost like it doesn't want to idle correctly. what could be causing this? i had my battery checked and it's good, and i just cleaned my air filter, so i don't know what it could be.
97 Contour GL Zetec + ATX Mesh Grilles Super-White Headlights Super-White Foglights Super-White Washer-Lights CTA Intake Removed Exhaust Resonator DTM Tenzo Muffler Removed Intake Resonator No More Badges Clarion AudioPro Headunit 4 Pioneer 6 x 8
Soon: Touring Wing Rims
Posts: 1,244 |
Check the MAF and TB, they may be clogged. Also check the IAT. Other than that I dont know.
Posts: 284 |
Sounds like the O2 sensor to me. My car had almost the same problem, except mine never stalled, the idle would jump from about 500 to 1100 RPM's when I was stopped at a light or when parked. Sometimes it felt like it was going to stall, but it never did. Have the O2 sensor checked, it may be sticking...
~*TJ*~ 97 GL Sport Zetec ~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
Posts: 35 |
how do i check to see whether the MAF or IAT or even the o2 sensor is clogged? should i just take it to ford and see what they say? i bought some fuel injector cleaner to add to my gas tank and i am gonna see what happens. i guess i'll update the situation later...thanks
Posts: 35 |
well, i put in the fuel injector cleaner and it helped give me great gas mileage, BUT my car is still cutting off at stops and i am throwing CEL's. i am gonna take it by ford to let them run a check on it. i guess it is my egr valve or something like that. i wanna get it fixed before i change from my KKM to my CTA. we'll see what happens...
Posts: 101 |
Happened to me once and the code was saying low cyclinder compression turns out it was a cracked spark plug maybe check those
1996 Champagne GL 4-banger (ATX) (I miss you baby) AIM:DJT81185 Replaced with 1998 Neon Coupe DOHC 5-Speed R/T 1.084 60' 2.549 330' 7.112 1/8 10.872 MPH 65.15 1000' 14.111 1/4 16.825 MPH 83.12
Posts: 35 |
well, i got my car fixed....it turned out it was the O2 sensor that had gone bad. It ended up costing me 300 to get it replaced, just cause i know the dude and he took OFF 200 dollars. is there anyone out there actually paying 500 dollars for this? just wondering....well, time to go put on the CTA...
Posts: 1,559 |
Umm I paid 60 and did it myself. I can't believe anyone would pay more than 125 for that!
Dude you go ripped.
Posts: 2,523 |
you = robbed
Did mine myself for $75. Takes all of 15 minutes to do. Someone gave you a killer wedgie.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 35 |
ah well, i'll just go to the tree outside and get more money....thanks anyway.
