TheMark Offline OP
I was curious if those of you with the 'lil bitty Dynabatt battery have experienced any cold-start problems thus far? I have heard that cold weather could be a problem for them, but was wondering if it actually was.
Thanks for the feedback.
~tm
The Mark
#464 of 6535
A Few GS-ish mods
Won't start your car at low temps. Some guy has one in hawai without probs. Thats as far north as I'd go...CCA is almost half of the stocker. Do a search, I posted the specs...
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
It's rated at 600 CA / ~490CCA
Stock max rating is 590CCA
2000 SVT #674 - Check it out!
F
F
Although I think the Dynabatt is a great mod, they are a bit suspicious in their amperage ratings. The stocker is rated for 590 CCA at 0F (like all CCA ratings), while the Dynabatt is rated for 490 CCA at 32F.
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Where did you see it was rated at 32F??? CCA is determined as follows:
For example, a 12 volt battery with 600 CCAs means the battery will provide 600 amps for 30 seconds at 0°F before the voltage falls to 7.20 volts (six cells). The higher the CCA, the more powerful the cranking ability.
For reference the starter draws around 60-70amps to run over. So even a Dyna-batt would start the car ~8 times without a recharge. There is no reason to doubt it's cranking power. It's design is far superior to a wet cell battery in efficiency. It's in "reserve time" that it is seriously diminished, but that is understandable considering the size difference. It has about 1/3 the reserve time. (that's roughly 30 mins) Reserve time is continuous use time at a 20 amp draw.
If you live in a cold climate, you should consider the CCA rating when choosing a battery. If you live in a hot climate, you don't need as much CCA.
Is this thing mountable in any position?
ie. ventless? Dry cell, what's the scoop? How
about warranty length? Thanks.
blk.99svt
n.e.Ohio
Never under estimate the power of stupid people in large groups...
W
W
The Dyna-Batt is a dry cell, so it can be mounted in any direction. I don't seem to have any problems with mine, but then again I live in S. Florida where it doesn't get to cold. I will say that it's been down in the upper 30's for the past couple of nights, and the car cranks right over. It also holds a great charge like when the car sat at Ford for 10 eek days while the tranny was being done.
2000 SVT
silver/blue #1699 of 2150
14.793@94.88
Sho-Shop off road y-pipe for sale($75)
