I
I
I have the Autometer gauge everyone here talked about. The problem I have is installing the sending unit. The head seemed the easiest. Just unscrew the plug using a 1/4" allen wrench then screw in the unit (said in all post about install).
1st - How do you break the plug? I've tried with 1/4" drive and could not even budge it.
2nd - Does the unit even fit in that area? It look like there is a pipe that need to be moved first.
3rd - How do you tighten the unit. I can hardly put my hand in that space let alone a wrench.
so you all don't think Im a complete idiot, I did install the other gauges with out help. wink
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
south country strut tower brace
A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio
Replaced resonator w/Dynomax Bullet
I tried to install Autometer sender in that spot. Got the plug out fairly easy, but the sender was too big to fit in that area. The pcv valve and hoses were in the way. Thoght about going with mechanical gauge, but saw a post where Terry Haines said best spot was to use the factory oil pressure switch hole. It's a pita to get to. Had to get the accy. drive belt loose, take the a/c compressor loose, and fit my fat little mitts up in there to get the swicth out and install fittings etc. I used braided line and AN fittings to run from block up to a tee. One side of tee has the oil press. sender and the other side has the factory switch, so I still have the warning light if pressure drops. Check out topic in this section dated OCT 29, 2001 (I believe) for further info. Almost forgot, had to take the oil filter off also for more room during the install and I've got a little more room than stock due to headers and remote oil cooler.
98 evo 0 SVT
#2999 of 6535
Silver Frost/Midnight Blue
Lotsa bolt-ons
I
I
Randyj - Thanks for the help. couldn't you of run the braided hose from the head instead of going from the factory sender unit?
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
I'm sure you can, but Mr. Haines recommends reading pressure from the block vs. head. I was installing remote oil filter and oil cooler at the time, so I just did it all then.(Had a long weekend).
98 evo 0 SVT
#2999 of 6535
Lotsa bolt-ons
Unbolt the a/c compressor so you can get behind it,go to the left of the stock oil pressure sender unit, remove the hex plug, fit the 'metric' autometer adaptor & use a 90 deg connection for the autometer line,care to endure the line has clearence behind the a/c compressor......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
I
I
It sure sounds easy when you say it that way. Ill try it this weekend and let you know how easy it was.
thanks for the help!
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
F
F
Buy a 45 degree angle adapter. I bought mine from napa. They took a look at the sending unit from Autometer and hooked me up.
Now the sending unit sits at a 45 degrees up and 45 degrees to the right. It works beautifully.
98 Mystique LS BLK V6 ATX and my bald head behind the wheel.
mods so far:
SVT Exhaust
215/60R15 Potenza RE950
Pioneer Premier DEH-P520 headunit with XM Radio
BNMotorsports gauges
KKM Intake
SVT side skirts
A pillar gauge pod with Volts, Oil Pressure. and A/F Ratio
