Page 4 of 4 1 2 3 4
The Website and catolog list the HP-2004 for my Jeep and it's a big 6cyl I hope this info helps you determine if you want to use it or not.
97 Ford Contour GL ATX 2.0L Zetec.
-KKM intake
-Tube behind MAF from 98
-Spraypainted grill silver
-SE spoiler
-Removed resonator muffler
-Wrecked
-Sold to Carmax
96 Jeep Cherokee Country ATX 4.0L I6 4x2.
-K&N FIPK cold air intake
-Jardine cat back exhaust
-APC halogen H-4 diamond series headlights w/sylvania cool blues
99 Dodge Avenger Sport ATX 2.5L V6.
-K&N drop in air filter
-http://www.Asog.net/ Sort of like Contour.org but for Avenger fans.
I compared the K&N filter to the Motorcraft filter and they were almost identical. Basically, they were the same size. Not sure about the inside construction, but I can't see how the filter could cause more oil pressure. Who knows?
1997 Contour GL Sport ATX
Zetec/2.0 liter
K&N High Flow Air Filter
Mobil 1 SuperSyn 5W-30
Mobil 1 Oil Filter (M1-204)
Fram Sure Drain System
Ford Motorsport 9mm Racing Wires
Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light
Pirelli HPs
Kenwood in-dash CD player
Infinity 5752cf speakers
World Champion New England Patriots Fan for Life!
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
Mobil 1 Oil Filter (M1-210)
Originally posted by ZetecRacing:
well I have been using this filter for OVER 30,000 miles and my engine is still running like the day I bought it. so I will continue using it but thanks for the info...
Well, the wrong filters worked on my Mitsubishi Tredia for a long time too, before they roasted the engine.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
O
O
I installed the HP-2004 yesterday, seems to towrk fine.
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper)
Suffice it to say my mod list has become so long that it is just ridiculous
Z
Z
Originally posted by Paul Kienitz:
[b]
Well, the wrong filters worked on my Mitsubishi Tredia for a long time too, before they roasted the engine.[/b]
and I'm sure if it was the filter that it didn't just happen over night.
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
No, I'd had it a year by then, and I think the previous owner had been using the wrong filter too. It may have been a matter of probabilities... like, every time I started it, a one in a thousand chance that the oil would fail to pump.
OOOOKAAAYYYY somebody somewhere is smoking crack.
I think on the box for the K&N which I have been using on two different cars, it crossrefs the correct fram oil filter for our cars. That is what you look at. More research??? OK. Take and crossref the fram back to the motorcraft.
It seems to work....Dunno why K&N would make a statement like they did. Again goes to the statement...the car is no longer in production so......
Any hooo.
Like I said two cars, one a 2.3 mustang with the PH8A filter refferenced to the K&N (believe it or not, the PH8A also fit my 67 Chrysler 383 engine) and the same goes for the Mystique.
I think you will be fine laugh
Rich
'96 Mystique, Zetec, MTX.
---Mods---
Removed both intake resonators and airbox. Installed APC air filter and APC crankcase ventilation filter. Removed exhaust resonator.
Installed XM Satellite Radio. Replaced bad alternator and 175a fusible link...much fun!
Intake plenum---GONE!!!!
My car growls louder than yours.
If I can't buy it, I'll build it...Trust Me!!!!
Z
Z
Rich
YES it does cross reference the Fram PH16/DG16 and the Purolator L14670/L26195 filters for our car on the box I'm looking at it as I type this... cause I'm putting another on of the K&N's on my car next weekend when I change the oil...
Joe Hartley
AIM: ZetecRacing
My Site My Profile
On another note, has anyone here tried to use the Mobil 1 oil filter, M1-204? It cross references with the K&N HP-2004 and the Fram PH16. The Mobil 1 site doesn't list one for our cars (surprise, surprise!), but I'm going to start using Mobil 1 now and have heard that I should use a Mobil 1 filter as it's designed specifically for their synthetic oil. Any thoughts?
Zetec/2.0 liter
Pirelli HPs
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
Page 4 of 4 1 2 3 4
