Page 1 of 3 1 2 3
#37546 01/01/02 06:33 PM
1
1
In the summer time, why would you use 0W30? I've never seen people here say that they use 5W20, but 5W20 is a thinner oil at operating temperature. 0W30 has the same viscosity as 5W30 or 10W30 at operating temperature, while 5W20 is thinner than all those. All Ford fuel injected vehicles changed to 5W20 from '01, even in the new 3L Duratec equipped vehicles. Maybe we should run 5W20 if we're just after a lower viscosity?
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
#37547 01/01/02 07:00 PM
a 5W20 and 5W30 will be the same viscocity at or below freezing.
0W30 is made for those extreme climates where the temps stay below 0F for extended periods of time. I really see no need for it in the continental US if you are running a 5W30 synthetic already. (Maybe Minnesota, North Dakota, etc)
The reason the new cars are going to 5W20 is GAS MILEAGE RATINGS. So the manufacturers can get away with making more SUV's. (High profit margin selling them to sheep) Yes there is likely an engine longevity penalty, but like manufacturers would care after the initial warranty ends. This penalty would be greatly increased on a high strung, high power, hard working/driven engine. Unlike the typical "commuter" driving most folks do.
BTW - Ford's 5W20 is a Semi-synthetic.
Matter of fact I believe all oils wanting to be SL rated will have to make this jump (educated guess at this point)
Guess there is something to a synthetic being better. :rolleyes: (to you folks - you know who)
2000 SVT #674 - Check it out!
#37548 01/01/02 10:02 PM
Administrator
Administrator
Plus, I have seen a lot of new cars that use 0W-20/30. It has to do with making the oil channels smaller, and "freeing up more power from the parasitic oil pump" or something like that.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#37549 01/04/02 04:12 PM
0W-30 has essentially the same viscosity at 212 deg F as does 5W-30 (9.7 cST v. 9.9 cST) according to Mobil 1 literature.
Does this mean it could be used in summer just as good as 5-30? Probably.
Most engine wear is purported to be caused at start-up, so thinner is better.
I checked my engine oil temperature several times in the past using an accurate digital temp gauge and found it to be in the 180-190 deg range, so it seems reasonable to use 0W-30 even in Florida.
Dan B.
#37550 01/04/02 04:14 PM
Also, mineral based oils can apparently meet SL specs. I saw a can of regular Exxon 5W-30 Superflo at Kmart that said it met SL requirements.
Dan B.
#37551 01/04/02 05:16 PM
F
F
I actually made the switch from 5W30 to 0W30 during the summer. Both oils cost the same for me and since they both have the same viscosity at operating temp, why not go with the one that will flow better at startup? Seems like a no-brainer, even if it's not as much of an issue during the summer. Now that it's winter, I'm sure the 0W30 stuff is causing less wear at startup... I mean it's almost like water even on a 20-degree morning.
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
#37552 01/04/02 06:34 PM
I'm Using 0W30 Mobil 1 and it is fine. I change every 3000 even thpough you can push the synthetic longer. Np problems. wink
98 EO #587
Currently Dirt Jumping
#37553 01/04/02 08:15 PM
Living here in SE MI I always run the 0w30 for the winter monthes. Sometimes the wind chill factors can dip to -20 below and I want the most protection available wink
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
#37554 01/05/02 02:24 AM
H
H
i use it cuz thats what amsoil racing series oil comes in
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#37555 01/05/02 03:40 AM
My brother and dad who farm run 0W30 in all their diesels in the winter as well as their vehicles - certainly makes for a much easier startup in the cold winter months! Even in my car the change from 5W30 to 0W30 is noticeable when it gets really cold, with 0W30 being the better choice for faster cranking. The car will start easily at -40C in a pinch with no plug-in wink
Dave
99 T-Red&Tan SVT/high flow res/K&N/painted grills & calipers/V-one/tinted windows/baby seat
#2228
93 Escort GT
Automatic (need I say more ->> it's the wife's car)
"I like long walks, especially when they are taken by people who annoy me"
Page 1 of 3 1 2 3
