Page 1 of 4 1 2 3 4
#37484 12/31/01 06:19 AM
Since I found out that the Contour and the Focus share the Zetec I did a little research. I check a few Focus archives and found out that a Focus R boasts 200+ hp! If I remember correctly it was a DOHC zetec with a blower! I've seen some of you guys say you post hp in the high 100's. Maybe a retrofit of this of the Focus R mechanics may help out a few of the Contours see REAL horsepower. Or could I be wrong?!?!? You guys tell me. eek
without stretching too far Terry could get a Zetec to nearly 350...
Gee just bolt a supercharger on the Duratec and it makes 325+ HP at the crank...
Your point is exactly??? :rolleyes:
BTW - It's a turbo on the Zetec...
2000 SVT #674 - Check it out!
HEY!!!! SCREW A V6. I LIVE ON THE EDGE. I TRY TO BET THE ODDS. THAT'S HOW I LIVE! I'M ONLY 5'4" SO I ALWAYS TRY TO BE DIFFERENT. IT'S FUN. AND IT'S A TURBO MY BAD! I'M HALF SLEEP FOR CRYING OUT LOUD.SHESHHH.
mad
...and wound a little too tight I see...
You stated the only way to get any REAL power in a contour was to fit a Focus R mechanic in it (oh - you mean engine right?)
YOU ARE WRONG!!! Someone even beat me to it as I posted the second response.
Madmole has a N/A Zetec around 200HP at the crank. Pretty impressive if you ask me. No forced induction.
BTW - if you BET THE ODDS you will only win half the time, but atleast you'll break EVEN...
Originally posted by Dr. Boom:
HEY!!!! I'M LAME FOR CRYING OUT LOUD.SHESHHH.
mad
uh huh
Spattmobili®
Some of us own both engines...
"I'M ONLY 5'4" ...sorry man laugh
"SO I ALWAYS TRY TO BE DIFFERENT."... Actually, turbos & NO2 are trendy. Now, being different actually means using old school techniques to improve breathing to extract N/A HP. cool
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Sorry to burst the bubble but the Focus does not use the same series of Zetec as the Contour, if you want to go with a Focus set up that is Ford based you would need the whole motor assy + its t/c or go aftermarket if you stick with the Contour Zetec....sorry!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Not bursting mine ... wife has a ZX2... laugh
Page 1 of 4 1 2 3 4
