Posts: 34 |
I already did a search but didnt really find what i was looking for. Is an Underdrive Pully worth buying and what kind of gains am i going to expect. How hard is the install and what, if any, problems will i face. Thanks.
1998 contour GL CTA Intake Resonator replaced with straight pipe Dynomax Super Turbo muffler 20% tint on all four windows. ding guards and all badges removed Aiwa MP3 head unit Cerwin Vegas in all four doors tweeters in A pillars 1 10" MTX 6000 run by a 300 watt mtx thunder amp. Fog lights, custom tachometer.
Posts: 650 |
ZetecRacing got 2hp and 8lbs of torque w/ his Esslinger pulley. I have the ASP pulley and like it alot, car feels less sluggish through the gears. The intalation isn't really that hard. What you'll need: Jackstands for the front. Socket set and ratchet Phillips head screwdriver Some WD40 or "breakfree" lubicant A friend to hold the brakes for you.
Buy a haines manual and it will layout the whole process for you. Really straight forward 2hour job.
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 34 |
ohsigmachi, can you buy the belts for them at autozone or something? and how much does the belt run you?
Posts: 650 |
I used the stock belt w/ the ASP pulley, the belt tensioner took the slack perfectly. I bought mine from KKM, WAAAAYY back in the day. The kit said to use such and such a belt but it turned out that belt number was for an escort or something.
Posts: 1,692 |
yes I have the esslinger pulley and i'm very happy with it much inproved acceleration just waiting now for ZXtuner to get me the alt. pulley.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 128 |
One of my friends had bought an AEM UDP for his 99 escort zx2. He crashed his car before he could put it on. I just want to know if the UDP will fit on my 96 zetec engine. And also if the belt will work.
Posts: 1,692 |
the pulley will work not sure about the belt... may need a different size... my 96 came with a 715 and I found it was too small I had to get a 721 and that was a little tight to fit on. when locozetecSE and I did his we had to use another size for his esslinger pulley than I did can't recall the exact size off hand though.
Posts: 3,950 |
Originally posted by ZetecRacing: yes I have the esslinger pulley and i'm very happy with it much inproved acceleration just waiting now for ZXtuner to get me the alt. pulley. But you put on a open air filter too. That is bound to give you some HP and TQ.
Posts: 139 |
Focus Central has a set of pulleys. Will these work? focus pulleys They are underdrive idler pulleys for alternator and water pump and whats the 3rd?
99 SE Zetec ATX CTA intake ZX2 FMS wires(that don't fit my oddball coil) andenthal@mindspring.com
Posts: 139 |
I had forgotten about this thread until Darksavior brought it up again and I looked for the link. Does anyone know if these will work? Same engine.
