#297790 04/13/02 03:34 PM
MB Offline OP
Hi, how do you change the spark plugs? i can get the wires off but how do you get the plugs out, do you need a special tool to get down in there to get it out? or do you have to take apart the engine, very confused...
Matt
'97 Pumice Zetec Sport- Superchip/Apexi DTM Tip/KKM/blue lights/removed door dings/De-Badged/ford racing 9mm-blue/Custom Interior/indiglo gauges
Audio
-3 JL Audio 10s/-2 kenwoods amps/-JVC cd head unit (with 12 disc changer)/-6x8 pioneers
http://www.geocities.com/mattbchillin
#297791 04/13/02 03:58 PM
Master P
Master P
Put a spark plug socket on the end of a 10" extension. That should get the job done.
When you put em back in, do not over tighten. Recommended torque is somewhere in the neighborhood of 10lb-ft. You don't necessarily have to use a torque wrench, just be aware of what you're doin.
#297792 04/13/02 03:59 PM
Is it a I4 or a V6 ? If it's a I4 the way i do mines is gently pull and twist grabing it at the base of the boot where it meets with the valve cover,not the wire it self. Good luck.
Later
Red '97 GL Sport MTX
IVELISE
"Let every nation know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe to assure the survival and success of liberty." John F. Kennedy
#297793 04/13/02 04:04 PM
Never mind didnt read the post right...it's been a long day already plus the beers dont help either. OK now that i read it right once they are loose i use a 12" long vacume rubber hose to pull them from inside the valve.
Later
IVELISE
#297794 04/13/02 10:36 PM
Spark plug wrench plus extension, then after loose take a magnet or like do like carrot_top.
'95 Tour LX
ZETEC MTX
TOO MANY MODS TO LIST ANYMORE!!
http://www.geocities.com/marine113
Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
#297795 04/14/02 03:30 AM
Sometimes it helps to put a piece of plastic bag over your spark plug socket when you take them out. It will tighten the hold on the plug and you can lift them right out. It beats fishing for it after you get 'em loose.
#297796 04/17/02 02:48 AM
All you need is an extension, a 5/8th inch spark plug socket, I believe. Loosen them and take them out. If you don't have a spark plug socket invest the whole $2 it cost at any auto parts store and get one. Very easy job.
~*TJ*~ 97 GL Sport Zetec
~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
