Posts: 226 |
i have decided to do a couple mods after reading about some stuff. where's the cheapest place to buy a cta intake kit at, and what magnaflow muffler part number do i need from summit. if i'm correct, these two things can be had for around $200. not bad for having a probably cooler sounding car and maybe a little more performance. will gas mileage suffer at all? will the muffler and removing the resonator be enough counter to the new intake and more air? the timing belt can wait a little bit longer.  ) thx
i will always have a comeback! :o)
Posts: 139 |
It will sound better and, yes, you will get better gas milage, as long as you drive it the same as you do now. You'll gain some hp so you might be a little more inclined to push you foot a little harder. I paid around $150 for my CTA intake. CTA Motorsports You can also go to the Mods section on the main page and see all the other, less expensive options. I haven't gotten to the exhaust yet, so I'm no help there. Have fun and welcome to the Dark Side. There is no turning back from the Dark Side. Embrace it and feel the Power flow through you.
99 SE Zetec ATX CTA intake ZX2 FMS wires(that don't fit my oddball coil) andenthal@mindspring.com
Posts: 5,805 |
timing belt can wait...not a good idea... :rolleyes:
Posts: 587 |
Have fun and welcome to the Dark Side. There is no turning back from the Dark Side. Embrace it and feel the Power flow through you.[/QB] lol.. Once you have your first Mod... you'll mysteriously never have enough money, anymore, and you will never have enough time, either. hmm.. wierd, isn't it? Ray
Posts: 620 |
The cheapest place to get the CTA is also the most expensive place: from CTA motorsports . I don't know which exhaust parts are good, I haven't done my exhaust yet. I found that the CTA makes my mileage worse because it just makes my foot itch to be pushed down more. When I took it out, I would push the gas, be disappointed, and give up on trying to go fast... mileage improved. I suspect that intake, exhaust, and chip pretty much covers the main affordable and effective mods. But seriously, the timing belt ought to come first. While you're at it do the water pump and change those little idler pulleys.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 3,950 |
Originally posted by tbunder: i have decided to do a couple mods after reading about some stuff. where's the cheapest place to buy a cta intake kit at, and what magnaflow muffler part number do i need from summit. if i'm correct, these two things can be had for around $200. not bad for having a probably cooler sounding car and maybe a little more performance. will gas mileage suffer at all? will the muffler and removing the resonator be enough counter to the new intake and more air? the timing belt can wait a little bit longer. ) thxHell yeah. I would do the timing belt first.
Posts: 226 |
yeah, i know. after coming back to reality and knowing i need new tires and a new timing belt and idler pulley, i will do these first. thx guys
Posts: 1,969 |
L8 Apexing Aussie (Anastazi)can get Magnaflow mufflers at a considerable discount.
Kharma is very real and she is one mean b!tch.
