Posts: 4,899 |
Rigging up a low fuel light would be some major work, as there is a new sending unit necessary, wires running up to the cabin, the light, etc.
Posts: 118 |
Like TheContourGuy, I would also like a low fuel light. With my Accord I could tell that I have about 30 miles left as soon as the light came on. As for my 96 Contour, the fuel guage is a piece of crap.
If it is just a resistive sender, it should be fairly easy to wire up a comparator circuit to light up an LED when the fuel level gets really low. Could someone who has expreience taking their dash apart put a meter on the gas sender line? This woudl tell us how low that we can go.
96 Contour GL (2.0L Zetec, ATX)
Sony CDX-C780 HU, Sony CDX-805 10 disc Changer, Sony XDP-210EQ, RF Punch 100.2 Amp, RF Punch 240.4 Amp, Dual 12'' Punch subs, Four Infinity Kappa 693.3i 6x9's, Optima Yellow Top
CTA Intake, Hood Struts, EL Ford Logo, Hi Beam/Low Beam Mod, Blue LEDs in door handles and footwells
Posts: 118 |
Opps, took me too long to post.
You shouldn't need a new sender. You could just tap the existing line and measure the voltage.
Posts: 118 |
Heh, just notice my sig mistake. Hopefully I'll get the bad Honda habits out of my system sometime soon.
(It said Vetec)
Posts: 3,934 |
If the fuel guage is as inaccurate as the temp guage that could explain why I can still drive the car even though the needle is pointing at the 'E' :rolleyes: I see where button puncher is coming from though. If you knew how much power was flowing through the lines with, say 50 miles left, build a circuit that will trip the light at that power rating. Could be annoying with fuel splash in the tank though. Would cause the light to flicker. I do know that this little project is out of my electronics knowledge though. Now for the second thing, do the `95 and `96's even have a spot in the guage cluster for a low fuel light? I know I have two fasten belts sockets, though only one works. I also have one that looks like a shock? WTF? A light for when my shocks wear out? That thing would be on all the time! :rolleyes:
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 1,537 |
TheContourGuy,
If you drove your car, till it ran out of gas, just to see the fuel warning light come on, then you, my friend, have other problems, and they are NOT mechanical or electrical.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 852 |
Dan , you're not a moron. I use the low fuel light, almost every week. Of course, if the gauge was accurate at all, maybe then i would not need it...
The low fuel light gives me a consistent 40 miles of safe driving. At least I can rely on that...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 4,319 |
Jeeeeeeeeeeeeeeezzzzzzzzzzzzzus.....
Will someone put a fork in this topic???
1991 GVR4 Lots of mods done.
Posts: 4,899 |
 here ya go neil....just for you.
Posts: 24 |
While my 95 SE doesn't have a light, I think the original docs suggested it did have one. Guess they didn't make it into the early years.
I do something else to figure out when I'm about to run out of gas -- other than look at the needle. Keep a little book in my glove box with every drop of gas or piece of maintenance noted.
Of course, the wife doesn't write everything down - guess it's not important to her until the CEL comes on - and the kids are always looking for paper to write on while in the car - but it helps with problem diagnosis.
Mike
