Posts: 1,244 |
Is anyone running sythetic in their Zetec? If so, what kind are you running? Is there any noticeable differences? Any other information I should need to know?
I was wondering because some of my friends are running it in their cars and they say it is a lot better than regular oil. I was thinking of running it year round.
Posts: 2,657 |
Posts: 113 |
i think it sucks...will never use it again. 80000 leak free miles before synthetic....3 leaks after. i know,, alot of people will say the synthetic did'nt cause the leaks but i'm not so sure
96 zetec gl.dynomax exhaust(self bent) KKM intake..Bridgestone Potenza RE-910's...other mods also 87' Ford Thunderbird..Now my daily driver ( the wife uses the contour mostly) true dual exhaust with the super mystery mod.(hey there not even there!) tinted windows and stereo upgrade. the $200 car is starting to be a great car
Posts: 304 |
Synthetic 5W is exactly the same runnyness as Dino 5W.
If you had an oil leak its because a seal has gone, not the oil you use
Some of us have been running Mobil 1 for well over 100K miles with no problems or leaks at all (and much less wear than others)
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
Posts: 364 |
I have 91,000K and running Mobil 1 5w-30.
Seems to idle smoother, lowers engine temp. Zetec seems to like it in the winter.
I use that and Motorcraft filter.
2002 Mitsui Lancer-Black MTX.
Posts: 81 |
I use Mobil 1 10w-30, never had any problems or leaks. I've been told it bettr for my car then reg oil, but I've never noticed anything different since I've started using it.
1999 Contour SE 4cyl Cabernet Red
Posts: 569 |
Mobil 1 in every car I ever owned, Never a problem.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 1,969 |
I'll leave this one alone But I do use Mobil 1.
Kharma is very real and she is one mean b!tch.
Posts: 2,657 |
Originally posted by redhawk: I'll leave this one alone
But I do use Mobil 1./sigh Thank goodness. :p
Posts: 1,969 |
Originally posted by SQPlus: Originally posted by redhawk: [b]I'll leave this one alone But I do use Mobil 1. /sigh
Thank goodness. :p [/b]OK smartass
