Posts: 92 |
Can a mechanical oil pressure gauge be used on the zetek or do i need to get the electrical one any help appreciated Thanks
97 GL Loaded Alpine,JL,fosgate system custom daul exhaust OBX intake intrax springs flipflop trunk tinted all the around
Master P
Master P
Posts: 5,455 |
Posts: 304 |
I used mechanical. There is a blanked off second oil sender location about 3" to the rear of the used one
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
Posts: 20 |
You have two 1/4" NPT ports on the intake side of the block. Unless you use a mechanical pressure gauge with threaded fittings, use an electrical gauge. The mech gauges with plastic/nylon capillary tubes are potential engine killers.
Posts: 92 |
might i ask why the ones with the plastic tubing may be engine killers just curious
Posts: 304 |
Mines copper piping (TIM) so its unlikely to melt like the plastic ones
Posts: 620 |
Originally posted by jag: might i ask why the ones with the plastic tubing may be engine killers just curious If the plastic or the guage ever fails, your engine sprays its oil all over the ground, or in some cases, all over your leg. That's why manufacturers stopped including them.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 20 |
I had to replace all bottom end bearings on my Zetec after a plastic oil pressure gauge split at the block fitting. Ironically I'd never trusted those with plastic lines, but I was holding off on replacing it till discretionary income was available. I'm now using one of those SPA oil temp/pressure combo gauges that also incorporates warning LEDs.At 5-6 bar, the sump is emptied very quickly. For a mechanical app, do as Madmole recommends.
Posts: 304 |
What worried me is how low the oil pressure has to be before the Ford warning light comes on. Basically the damage is done way before it lights up You guys who damaged your engine's were not obviously watching the oil pressure guage then Just for info, when cold my oil pressure is 80 psi when hot idle is 30psi and revs are 60psi Hot is 80C on freeway, 90C town, max 100C in traffic (Oil cooler fitted)
