#294347 11/22/01 06:46 PM
labelle Offline OP
i have the pik's for the pre 98 intake .
on cd ,but cant figure out how to post them
please help confused
96 2.0 mtx
kenwood deck & amp,mtx cr, boston acustics,12inch phonix gold
45sq feet vibration dampning/sound proofing
15%tint
98 rims ,fire gta's
factory tack install
k&n ,intake res removed
accle thunder , ngk
custom exsaust
redline/fm , waterwetter , sy oil& stp
svt mounts
jet chip
#294348 11/22/01 09:55 PM
Master P
Master P
Can you get em off the CD and figure out how to email them? I can host em...
email em to perry @ webmasterp . com
#294349 11/25/01 01:47 AM
Kai Offline
Introducing Perry: The Anti-spam! Love that email with spaces! laugh
Try to get the pics to Perry, though! Me wanna see! smile
Kendall
'97 GL Zetec ATX
" Nippy "
#294350 11/25/01 02:59 AM
Master P
Master P
He did email me the pictures, and I uploaded em to my web site and hold him to post the link... I guess I'll go ahead and post it myself..
http://www.webmasterp.com/labelle/
#294351 11/25/01 03:04 AM
Lee Offline
Someone is in serious need of a FLASH! eek
Otherwise it looks great.
Lee Cox
In life begins responsability...
Project Car
#294352 11/25/01 05:29 AM
I installed the CTA intake in my pre-98, and there were a couple of awkward areas. For one thing, the pipes were basically a bit too short! The cheezy bracket that's supposed to hold up the MAF had to be bent back so the MAF could reach it, even with plenty of slack in the middles of the rubber joint tubes. I almost think I could fit an e-ram into the tube without cutting any metal off of it. An inch at the most.
Getting the filter onto the MAF was hard. In the end I had to lube it with some spray silicone (sprayed onto paper towel and wiped on)... and then pull out little shreds of rubber that came off during the struggle, from the ridges moulded inside the filter's fitting.
The simple hole to screw the IAT sensor into is a somewhat unfortunate compromise... it leaves much more of the sensor sticking into the airstream than in the original design, and the hole isn't going to be all that re-threadable. I would recommend some kind of nuts or bushing on some of the threads on the sensor so that it doesn't screw in all the way, and/or using some kind of thread-lock.
It works. It cut about 3/4 second off my 0-60 time. But not when the engine gets hot. The name "cold air intake" is a misnomer; it's quite vulnerable to heat. I am puzzling out different options for how to get more cold air up to the top of the engine compartment. It's hard to snake any wide tubing through there. A good first step would be to pull all the remaining plastic out of the wheelwell opening.
The instructions assume a lot; I may offer Chris a rewrite.
The noise it makes was fairly startling at first. At half throttle you have to raise your voice a bit more than you're used to; at full throttle it makes a howl loud enough to be a territorial challenge to any nearby hot-rods.
So now I'm figuring, what the hell, I don't have too much to lose if I get a somewhat louder muffler...
Here you can see the bent bracket, and a bit of foam I stuck down to cushion the filter from bumping against the body:
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#294353 11/29/01 07:49 PM
labelle Offline OP
Parent Directory
need a better flash too.
second time i took these
one of iat turn out ok
96 2.0 mtx
15%tint
98 rims ,fire gta's
accle thunder , ngk
custom exsaust
svt mounts
jet chip
#294354 11/29/01 11:09 PM
E
E
try some of that heat retardant wrap used on turbo chargers. a firend has it on his eclipse turbo and after running for a hard 1hr then pullin tape back it wasnt near as hot. might be worth a try. i am going to be picking up a cta as i like it better than just the kkm filter. when i do i will be trying the heat tape.
eric
_Eric_
95' Performance White Contour Gl Zetec ATX
-A beautiful girlfriend next to me...what other mod is important?
#294355 11/30/01 10:58 AM
Be careful. When I fitted the similar AEM short ram, I lost 9 HP in the mid range for a 2HP gain. Felt more powerful and there was more of a hit at the top end buit the dyno showed it was killing my mid range
Massive airflow can seriously hurt you mixture at wide open throttle
Fortunately I have a Unichip so I could change the maps to no loss at mid range and a 7HP gain at 6000.
Watch out for small children on the sidewalk if you fit one laugh They tend to get stuck in the filter laugh laugh laugh
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
#294356 12/03/01 01:52 AM
Paul
I am curious as to why you did not turn the bracket around 180 degrees to move the MAF closer to the engine. Wouldn't this help move the MAF closer so that the overall length of the intake becomes shorter?
ALso, we are more than happy to take your offer for a rewrite of the instructions. smile
