Hi Guys,
Sometime ago I took the decision to improve the performance of the brake system on my ?Tour? by installing a set of Aeroquip (stainless braid exterior) Brake Hoses, which I procured from BAT Inc. However, ever since then I been experiencing some very strange behavior from my ABS System, Radio & Keyless Entry System the nature of which is as follows.
Whenever, it rains my ABS warning light comes on and stays on, in addition, my Radio continues to play and the Keyless Entry System does not function despite the fact that the key has been removed from the ignition. This gives me the impression that something is causing the ignition circuit to behave as if the key is still in ignition switched to the accessory position. However, as soon as things dry out every thing returns to normal and all systems function properly. Could all this be a result of the BAT Inc Aeroquip (stainless braid exterior) Brake Hoses i.e. could their stainless braid exterior be causing an electrical short circuit when they become wet results in the above-mentioned problems. Do any of you Guys that have these Brake Hoses installed experience any similar problems?
Looking forward to the usual helpful comments, opinions & suggestions
