#293801 10/29/01 02:24 AM
E
e-mAn Offline OP
E
i am about to order a diablo chip from CTA and i would like to know if it can be programmed to run on regaular unleaded gas??? i will get it prg. to run with the medium gas if not thanks
_Eric_
95' Performance White Contour Gl Zetec ATX
-A beautiful girlfriend next to me...what other mod is important?
The whole purpose of the chip is reprogramming the fuel mapping to run on premium gas to make more power. If you had a chip programmed to run on regular you would'nt notice much of a difference except for raised shift points and the removal of your top speed governor. Get the chip as it was meant to be used and it will be money well spent. If you cant afford premium gas try an octane booster. If you can't afford that...well
98 Contour SE Zetec ATX
"Chevy Corsicas Fear me!"
"There's no such thing as a PRETTY GOOD alligator wrestler"
But octane booster is more expensive than premium gas. Unless you use raw ethanol or something from Grandpa's still...
Keep a bottle of it in the trunk, though, in case you're stuck in the boonies where they only have regular.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
That's more or less what I was geting at
i had a diablo chip in my zx2, ran better, got better gas mileage form 89 octane than 92/93 octane.
peace
stephanie
Yeah, run the premium. With the computer remapped, you should get better gas mileage anyway. My guess as to why I don't see an improvement with 92 right now is because it just isn't programmed for it.
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
You can probably get away with that as long as you don't run into hot weather.
Well my car seems to run better(quicker) with mid grade 89/90 gas. I run premium I feel no difference. If I had access to free dyno I would test that theory. laugh
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
