#293692 10/24/01 11:47 PM
E
eric j Offline OP
E
I just removed mine and three out of four posts were cracked and the copper connectors of my wires were oxidized (turned green from some kind of buildup). No wonder my car was jerking at low rpms and accelerated poorly from a standing stop. I had the coil for about 7 mths. Those of you that had it for a while might want to check yours just to be on the safe side.
1996 GL Zetec
KKM Air Filter,Brembo Rotors,KVR Brake Pads,Koni Struts,Eibach Springs,Focussport,Spark Plug Wires,Accel EDIS Coil,Speedo with a tach,BNMotorsports white face gauges ,E&G Classics Billet Aluminum Grille,B&M Shift Knob,Richbrook E-Brake Handle Cover,98+ Sail Panels,PIAA 510 fogs,Badgeless
#293693 10/25/01 01:18 AM
F
F
HA! Its a trend. I sent mine back today, same problems. Jerking and crappy acceleration off the line.
Nick F.
01 Focus ZX3 MTX
borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec
Yes its a zetec, we were here before vtec, so we are not copying!
#293694 10/26/01 10:29 AM
Just to let u know that the zetec wires get very hot and the dieletric grease breaks down from heat. You need to buy some greese and gunk alot in there. Talking about the terimals and boots of the spark plug wires and coil......The low end jerking is from miss firing in the wire from the coil, plus make sure there is not heat deteration from the excess jerking and heat..
email me any questions
Chris Bauer - VP
T.C.R. Motorsports
eek
