Posts: 546 |
Watch out! I felt my car jerking here and there, so i got to wondering what it was. Started the car up ppened the hood, revved it up. Heard a sparking sound, so i did it over and over. Found it finally, looked are the coil pack and there was sparking going on. The bottom left terminal. Hopefully it has a warrenty.
Nick F. 01 Focus ZX3 MTX borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec Yes its a zetec, we were here before vtec, so we are not copying!
Posts: 2,657 |
I've got a stock coil I can lend you if needed in the mean time. FYI.
Posts: 546 |
I still have my stock one. Thanks for the offer though. Jegs is going to replace it for free. hopefully it wont mess up this time around. Thanks again.
Posts: 2,657 |
No sweat...have fun.
Posts: 63 |
I had the same symptoms, and after checking under the hood today, I noticed I have the same problem. Random sparks around the lower left terminal. I had my coil for about 6 months. I hope this doesn't turn out to be a more widespread problem.
1996 GL Zetec KKM Air Filter,Brembo Rotors,KVR Brake Pads,Koni Struts,Eibach Springs,Focussport,Spark Plug Wires,Accel EDIS Coil,Speedo with a tach,BNMotorsports white face gauges ,E&G Classics Billet Aluminum Grille,B&M Shift Knob,Richbrook E-Brake Handle Cover,98+ Sail Panels,PIAA 510 fogs,Badgeless
Posts: 304 |
Why bother, theres nothing wrong with the Ford one. Very reliable and more than powerful enough.
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
