Posts: 1,202 |
Originally posted by Kai: I suppose North Carolina is too far away?  LOL, yup. If I get an answer shortly on the IAT issue, the kits will be right there for the Pre 98's.
Posts: 22 |
hey chris, i notice your in brampton , im about half an hour away , i was going to build an intake soon , i want a threded hole to make it proper. could get together on this .
96 2.0 mtx kenwood deck & amp,mtx cr, boston acustics,12inch phonix gold 45sq feet vibration dampning/sound proofing 15%tint 98 rims ,fire gta's factory tack install k&n ,intake res removed accle thunder , ngk custom exsaust redline/fm , waterwetter , sy oil& stp svt mounts jet chip
Posts: 1,202 |
Originally posted by labelle: hey chris, i notice your in brampton , im about half an hour away , i was going to build an intake soon , i want a threded hole to make it proper. could get together on this . You got mail
Posts: 669 |
does this mean that there could be a pre98 intake here pretty soon....oh that makes me so happy, (tear in eye)........
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Posts: 243 |
I hope there will be I was looking at putting an air intake on my car this winter.
96 Contour it's faster than a period. some day I will be as fast as D Davis
Posts: 730 |
Yee haw! The end of " Under Development" is in sight! And the wheels are on hold 'till the tires wear out, sooooo......
Kendall '97 GL Zetec ATX " Nippy "
Posts: 620 |
Originally posted by cawong11: LOL, yup. If I get an answer shortly on the IAT issue, the kits will be right there for the Pre 98's. Some time soon I'll measure all the dimensions on my sensor as best I can and let you know.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 1,202 |
Originally posted by Paul Kienitz:
Some time soon I'll measure all the dimensions on my sensor as best I can and let you know. Thanks.
Posts: 620 |
Now these measurements are not micrometer accurate, but hopefully if the thing is some kind of standard metric thread, this will let you recognize which one. To make sure, of course, you could just order a sensor from Ford.
Posts: 22 |
I am going to see chris tomorrow to get it fit for pre 98's .
