Posts: 178 |
So whats the Zetec thinking on an adjustable fuel pressure regulator? I searched the topic but nothing on the zetec just the V6. I've used this on other cars to pretty good effect why not the zetec? I would appreciate your oppinions Thanks
'69 Chevelle SS '99 Mystaque GS
Posts: 304 |
Over our side of the pond an FSE valve (Adjustable fuel pressure regulator) is a very common mod. It cures the flat spots caused by fitting free'r flowing air filters
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
Posts: 422 |
I read about this cheap mod in SCC. I am very curious too. Also in SCC they talk about putting the Fuel Pressure Gauge right on the tubing. Why not move it to say the A pillar pods? Again, As anyone done this?
98' Black Contour Sport GL Zetec ATX KKM;No Res;Dynomax Muffler;Custome pedal kit;Custom ATX shifter;A-Pillar Gauge Pod w/Voltmeter,A/F Ratio,Oil Pressure Gauges;Side Markers;Zetec and Limited Edition Emblems;Custom Headlamp & Taillight covers;Tinted windows;Ram Air Induction into KKM;Front Strut Tower Brace;Custom Upper and Lower Mesh grills;885 Fog lamp bulbs;Rear Dome light;Ventshades;Remote Start;Headlamp & Taillamp Strobes;Stereo system
matthewbounds@hotmail.com
Posts: 178 |
Well mine was orderd before I posted the question so we will see as soon as it gets here. I was just looking for oppinions. I ordered the FSE from need for speed. Madmole are you running one?
Posts: 304 |
Yep I have the FSE, it helped with flatspots before I got a Unichip.
Does have a drawback though. Mine tends to let the fuel pressure creep up. I set mine for 3.1 bar (Standard is 2.4) but after a month or so it slowly creeps up to 6 bar which causes the injectors to dribble at idle and pushes emmisions right up.
Now have the AEM Focus pipe fitted (Pig of a job, not a direct bolt on)
Posts: 304 |
Yep I have the FSE, it helped with flatspots before I got a Unichip. Does have a drawback though. Mine tends to let the fuel pressure creep up. I set mine for 3.1 bar (Standard is 2.4) but after a month or so it slowly creeps up to 6 bar which causes the injectors to dribble at idle and pushes emmisions right up. Now have the AEM Focus pipe fitted (Pig of a job, not a direct bolt on) lost 9HP at 4000 rpm. Good thing I have the Unichip so after a quick remap I got an extra 7Hp at 6000 rpm So grand total is now 166 FWHP (195 BHP flywheel)
