Posts: 9,178 |
Which one should I get? I really want to get an intake and I want to get the best one for the money.
Posts: 983 |
CTA!
the kkm isn't impressive anymore.. and in canada it's about the same for both... so i would say CTA!
1998 Vibrant White 2.0 Zetec / "Powered By Ford" Shoulder Pads / 3A Racing Pedal Covers / Pre-98 Sail Panels / Alpine SPS-5729 in the front / JL Audio TR570-CX in the Rear / Zetec Inside Sticker / Replica Porsche 944 Rims (5 circle ones) / CEG Sticker / Super White 9006 Low Beams / Euro Style Short Antenna / Broadway Wide-Angle Mirror / Painted Front Grill Vibrant White / CTA Intake / Accel Ignition Coil / Diablosport Chip / Dynomax Super Turbo Muffler / Ractive Amber Side Markers / ST200 Struts / Eibach Springs
Posts: 107 |
I had the KKM and then installed the CTA.. I would have to say the CTA is much better.
GroundZero74@aol.com 96 Zetec Contour Custom paint job, shaved door handles, touring wing, 17" white Team Dynamics Monza rims on 225/45 Nitto's, Power Stop cross drilled rotors w/ Axis pads, stainless steel braided brake lines, Eibach/Koni suspension, strut tower brace,Superchip, CTA intake, Nology wires, Nology plugs, Accel coil pack, Optima battery, NOS, high flow cat, stainless cat back w/ weapon r exhaust, Corbeau racing seats,simpson 5 point racing harness, paint highlighted interior, racing pedals, diamond plate floor mats, white face gauges, headlight strobes, under car neon kit, Pilot fog lights, PIAA driving lights,custom side markers, 20% tint all around, Fuba antenna, Kenwood mask headunit, Kenwood PS series amp, 12" Kicker Solo Baric, infinity kappas in the doors, Street Wires wiring.
Posts: 546 |
Nick F. 01 Focus ZX3 MTX borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec Yes its a zetec, we were here before vtec, so we are not copying!
Posts: 52 |
GroundZero do you have a pic of your car online? Would like to see what it looks like?
Toohey
Posts: 107 |
Here you go Toohey...
Posts: 1,559 |
Ground Zero, did you see a big improvement with the Nology plugs, and wires with the accel coil. I've been thinking about getting those and was curious if it would help. Thanks.
Posts: 2,246 |
i will be buying the CTA as soon as I have the money
David Litsky AIM: DaveL225 My Car
Posts: 107 |
The Nology wires are a big improvement.. but they are costly. The Nology plugs are a nice improvement as well. I wanted to keep the plugs and wires as a set to get the most out of them. The accel coil pack helped out alot. My Tour being a 96.. it was time for a new coil pack and you could feel the difference as soon as I installed it. I would defiently have to say all 3 made a great improvement in performance.
Posts: 19 |
where you from groundzero ? i have a 96 and im working on it , i have custom made 2 1/4 "dual exhaust 9mm ford wires on the way and im getting the coil and some other things id just like to talk to you to see some differences
