Posts: 974 |
Sorry guys, I think that tbunder has a point and so does tboner. I am cheap and with all the little fixes these cars need, I can't afford to throw down money on preventative maintenance. Then again if I was to go on another long trip, I would probably chicken out and replace the belt. I am glad we are at least agreeing that the belt won't cause any damage per say. But ya, I would hate for it to go out as I was pushing past a big rig. To each his own!!!
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 226 |
its been fun guys, but i think we've (or I) beat this thing to death. i love my cheap, underpowered, awesome handling, rare colored, not decontented, tachometer equipped, like new looking paint, cool directional oem aluminum wheel rolling, loaded up little portofino blue mystique. and until it hits 100K, i will not violate its virginity.
i will always have a comeback! :o)
Posts: 620 |
Originally posted by madmole: Having extensively re-built and ported my Zetec, I'm pretty sure that the valves and pistons will not meet if the cam belt goes south... The manuals say they will meet. And if they do, then you are gambling like $100 worth of difference in when you have it done, vs. more or less the cost of a whole engine.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 1,493 |
One question, has there been anyone in these forums that had their belt break on them and when did it happen? (Well, actually two questions.)
I do know folks who had their 1.9L Escort's timing belt go at 80-100K miles.
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Posts: 109 |
Not a Ford, but an old 1st gen Integra I had popped its belt sitting at idle, and the damage done was around $800 worth, and that's with a family-friend mechanic saving me as much $$$ as he could. I REALLY don't want my Contour doing the same thing.
Posts: 594 |
For the record my 95 Mystique has 96 thousand and it has the original timming belt on it. I will be honest and I push the car hard sometimes, the only thing I have noticed it the belt tapping the cover and a bearing making noice in the tensioner or something else somewhere. As for changing the belt, I do not know what i am going to do. For now it stays but 100 thousand sounds like a time to change it and that bearing that is making noice
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 34 |
Examine the belt and if it does not show signs of damage wait until 70K-75K miles for replacement.
Posts: 761 |
My Mystique has 69 on it, and I do worry about it, but not sure what to do with it yet. My 95 Tracer's belt broke finally at 87k, big PITA, 3AM Sunday morning 80 some miles from home, but I do have AAA and was glad of that  was 6AM before I got home.
Posts: 546 |
I changed mine at 80K even though the belt looked new! Just freaking replace it, its called maintains! What?s the difference if you change it a few thousand miles later? Just change it...... Also this topic has been covered several times, use the search feature. No flames meant to be thrown here.
Nick F. 01 Focus ZX3 MTX borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec Yes its a zetec, we were here before vtec, so we are not copying!
Posts: 226 |
just updating you. my '97 mystique zetec in portofino blue (very cool color) now has about 98000 miles, and its still got the stock belt on it. still noisy at startup due to the cover rub, but still gets anywhere from 26-31 mpg depending where driven. just added a can of restore at last oil change. it doesn't burn a drop of oil either. at 100K i will change the belt, plugs, wires, rotor or whatever it has, tranny fluid, maybe a coolant flush. i love her. a downright cheap ride that's one of the most reliable cars i've owned. will cruise at 75 or 100 if called upon. good luck guys
