#291291 05/02/01 05:22 PM
crank Offline OP
I got a little on 1 of my plugs tiny electrode before installing plug. I wiped and installed. Should I have scrubbed harder or dipped in a degreaser? I am assuming with the temp and all, that the spark plug will clean itself when running hot for a while!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#291292 05/06/01 07:40 AM
You should be OK
By the way NGK specifically say NOT to use anti seize on their plugs.
I've never used it on any plug and never had a problem, too much risk of the goo contaminating the chamber. It can do increduble damage to the plug and if the threads are correctly cut the paste can allow overtightening.
Have a look at the NGK web site
NGK Web Site which is full of good info
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
#291293 05/07/01 01:05 PM
crank Offline OP
I used the motocraft plugs! Does anyone know if Ford uses antiseize on these plugs?
2001 Cavalier
150-175 more kms
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
