Posts: 1,969 |
Anyone know how to remove the trim pieces on the dash on both sides of the steering column? Also how do you remove the trim around the guage cluster- not the dash itself but the black piece around it?
Lastly, how do you remove the shift selector handle on an ATX?
I'm planning on doing some interior mods but the Haynes manual isn't very clear about removing these pieces.
------------------ Atlanta, GA 1999 Silver Frost 2.0 SE Zetec K&N Filtercharger Mintex Street Pads BAT Rotors Sony ES Mobile Xplod Pioneer 3-way 6X8's all around BAT Bright Whites
Kharma is very real and she is one mean b!tch.
Posts: 361 |
Redhawk,
for the trim on the top dash, remove 2 screws from inside the gauge cluster inside the 2 deep grooves inside that plastic piece, remove 2 other screws from behind the dash clock or the plastic piece that has contour on it , and you will have another screw or 2 behind the defroster switch.
now, the trim pieces on the lower side, fot the left one you will need to remove the lower left panel first above the knees. and under it there will be screws that you will have to remove and then pull that little black piece a bit hard.
for the right one, I don't recall perfectly, but I remember having to pull it hard with care to snap it out of place. just hold it tightly from inside the radio opening and pull, might help to lubricate with some oil before pulling out.. by sparying the edges from inside. just make sure you remove all visible screws. Good luck.
So what are you diing with your tour?
Posts: 1,969 |
How do you remove that "contour plate" and defroster switch without breaking them?
I am doing some detail work...
Hopefully, if everything turns out, I'll have some pictures for you.
Posts: 94 |
Whatever you do, be it prying or whatever, be CAREFUL! Whenever you whip out a flat blade screwdriver to pry up / snap out the pieces, make sure you don't ding up the plastic. The pieces are pretty soft and it's easy to put unsightly scratches/cuts/grooves/whatever in them. Just take it easy or wrap the screwdriver with a cloth...
As for the Contour nameplate, I can't help you - I've got a 96. The defroster switch is probably in a different place, too.
'96 Contour Zetec + mtx -KKM -ATP 5 Razze 16" wheels -Nitto 450 205/40VR-16 tires -Banzai 16" pre-muffler -Dynomax Super Turbo muffler w/ tip -Autometer tachometer -black antenna -aftermarket fogs -blue-painted calipers and drums -knauberized -badgeless -silver-painted seat base -mesh grill -KKM pedals -Richbrook gear knob (silver) -Weathertech front mats -Sylvania Cool Blues (high + low) -blued out lighting in footwells, glovebox, and trunk -billet oil filler cap
Posts: 178 |
Mine are falling off (broken) whats the best thing to glue them back with or should I just let the dealer have it?
------------------ '99 Mystique GS ATX K&N Glasspack & Flowmaster UDP(still in box) 15" AR Carerra's Alpine Sony & JL Audio Sounds (weapon-r on the way) "for when 109 aint so fine" 83 Jag XJ6
'69 Chevelle SS '99 Mystaque GS
Posts: 1,089 |
slowpoke,
If the car is still under warranty, let the dealer fix it.
------------------ '98.5 Mystique GS ATX/re-contented door lights/K&N Filter/Energy Suspension Sway Bar Bushings/Mintex Street Pads/high-beam bulbs in low-beams/Pioneer DEH-P3100 receiver/Pioneer TS-A6855's in all doors
Justin '02 Ranger Edge ext cab Retired: 98.5 Mystique
Posts: 2,657 |
Originally posted by redhawk: Lastly, how do you remove the shift selector handle on an ATX?
The only way to remove this, that I have found, is by breaking the wires off the O/D switch. There is a small hex-head screw in the drivers side of the handle. About in the middle. After you remove this the handle can pop up but it is still connected through the O/D wires. Good luck... ------------------ Brad W. 1998 Silver Frost SE brantleyiii@earthlink.net Photopoint Album ------------------ "Good leaders are scarce, so I'm following myself."
Posts: 361 |
Once you remove the handle the Od switch can be sled outward..pulled outward slowly..this way you will have to disconnect or free the wires from inside the gear panel..I know this cause I once gota wood gear handle from a wrecked mystique..
