Posts: 926 |
Will these babies bolt on to our trans? What are the low HP and TRQ numbers? Finally, cant these engines take Turbos?
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 1,184 |
my question is not if it will fit on the tranny but if the tranny can take to power
1996 Mercury Mystique stock (so far)
The leading cause of Atheism in the world are Christians, who accept Jesus with their mouth but walk out the door and deny him by their actions. (*DC Talks greatest hits. track 15)
Posts: 178 |
in turbo form they are rated 204hp + like the Sierra Coswoth Escort Cosworth ect... This is in detuned for the street a lot of Fords performance cars got the Cossie in the rest of the world. Turn up the wick on these motors & 300+hp is easy to come by. I dont miss much about the old country (Hell after 26 years here I dont remember much) except the awsome cars the facory cars created so they could go rallying. These motors ROCK!!!
[This message has been edited by slowpoke (edited January 20, 2001).]
'69 Chevelle SS '99 Mystaque GS
Posts: 0 |
Yes the Cosworth YB series engine will physically bolt to your Zetec tranny. There might be a problem with the cossies big flywheel though, the cossie use a 240mm clutch.
They are turbocharged in std. form although I believe that Ford Racing Performance Parts sold NA versions in the US a while ago.
The engine is rated at 204HP @ 6000rpm and 200lb/ft @ 4500rpm
Later version had 220 - 227hp and a bit more torque both peak and at a lower rev.
It`s a beautiful engine and very tuneable.
------------------ Arne Ford Sierra Cosworth 2wd Stage1 270hp @ 1.1bar
S B ANDERSON
Posts: 5,805 |
Yes the 2.0 Cosworth will mate to the Zetec MTX75(not the duratec).This is a track option for the 'beast' on my site.New Cosworth (genuine!) engines are expensive.I have contacts and can build you a t/c or n/a version if you are interested.TAH ------------------ V6 MTX 'Buy the tools and dodge the fools..." 'Its only nuts & bolts!' Terry's Website
Posts: 926 |
What is the t/c 0-60 times?
Posts: 926 |
What makes the Cosworth different from the Zetec? How much to have one imported?
[This message has been edited by Sasmaster6000 (edited January 24, 2001).]
Posts: 5,805 |
In UK 'retail' long block cost(no intake ,exhaust ,accs drive etc)around 6-8,000 UK pounds (x around 1.4-1.5 exchange rate and add the shipping!)$$$$$$ ------------------ V6 MTX 'Buy the tools and dodge the fools..." 'Its only nuts & bolts!' Terry's Website
Posts: 926 |
I think Ill stick with the Zetec!
