Posts: 63 |
Well remember that computer and timing mod I did. ell me and my buddy raced. He was about a car length ahead (because of 5 spd)of me and as we got to the century mark I just all of sudden flew by him like he was standing still! He was so pissed and I said " WOW"! I do however have to run 93 Octane though but who cars I made me some history! I hit 110 and he was about two car lengths behind and he even DIDN'T hit his governor!! Woody woo!! Zetec Dave 99 SE Zetec ATX No res, KKM, etc
Zetec Dave 01 Infra Red Focus ZX3 Custom Dual Exhaust, AEM Cold Air Induction, Focussport Wires.
Posts: 4,983 |
You lie!  J/K! Good kill! ------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX PIAA SW 9006 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps PIAA SW H3 bulbs Sidemarkers DRL Relay Llumar Platinum Plus 35% tint Maxxis UA603 205/60HR15 tires KKM Tru-Rev intake www.geocities.com/patmvaldez
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 63 |
He still beats me at take off though. Must be that MTX 75 under the hood. Compared to my slush box  ! O well! I still killed him at high speeds! Zetec Dave 99 SE Zetec ATX No res, KKM, ETC..
Posts: 884 |
Computer and timing mod? Do explain. I don't see this being possible except with a chip if so, then the chip is what did it.
John
Posts: 316 |
i don't even bother with them anymore cuz all i have to do is 1st and second gears to beat them.i gave up on them
------------------ 95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust- dynomax magnum with hooker headers exhaust tip focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar koni's with h & r's svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears ford racing alum intake
next: header(which might not work) msd or jacobs ignition quaife a borla muffler( a loud one)
95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust-borla muffler focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar spax and eibach svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears
Posts: 63 |
Well the Zetec Engine comes from the factory with a emissions legal exetent on the fuel flow etc. Well this guy wentin with the computer and completely erased my whole computer and reprogrammed it to read the max. So he said I have full power coming from the computer. He said it does exactly what a chip would do, and seeing how I flew by my buddy like he as standing still I asumne it works, since before I could never do that. C-ya! Zetec Dave 99 SE Zetec ATX No Res, KKM, etc.....
Posts: 884 |
So basically you didn't do anything, just pretty much reprogramed the ECU. Where did you get it done and how much?
Posts: 63 |
There is this late night mechanic that knows how to mod every ford car. The Zetec Engine is the easiest in the inline 4's. He described the mod as ford legally gives you emissions ___________ but when he reprogramed the ecu it maxed it out____________________________________ and he said it does everything that the cips would do, better timing, no speed limiter etc.
------------------ Zetec Dave 99 SE Zetec ATX No res, KKM, etc...
Posts: 884 |
Soo, you didn't do anything, you just had the ECU remapped. How much did that cost and where did you get it done at?
Posts: 63 |
It didn't cost anyhting and only took 5 minutes. The tech at my wqork did it. Just find a friend that works in the service department and tell them your check engine light comes on and off and you need to talk to the tech. By the way this is illegal??
