Posts: 93 |
Does anyone know how to install a tachometer in the zetec? I don't have one, but I want to install one? Are the wires there, for a plug in?
------------------ Nick
Nick, Sprout2287@aol.com, '01 Focus ZX3, Red, MTX, Injen Cold Air Intake, Kicker Speakers, subs, and amps, Dei Viper Alarm.
Posts: 4,983 |
I was wondering that myself. I'd like to install a small tach somewhere on the dash.
------------------ P. Valdez 1999 navy blue SE Zetec ATX PIAA 9006/H3 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps Sidemarkers DRL Relay Maxxis UA603 205/60HR15 tires No performance mods yet!
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 3,774 |
the wires are all there. i'll take a look at the tach i have and let you know which contact of the wire harness is for power/ground/signal. i might do that tonight or tomorrow.
ok?
1995 GL Zetec MTX...Light Blue Born: July 1995 Purchased: November 997 KKM Intake Superchip AR 16x7.5 w/ Dunlop W-10 (205.50.16) Viper 500+ Alarm Sounds by: Pioneer CD/Polk dB/MTX Subs/Alpine Amp Richbrook Shift Knob "Recontented" Factory Instrument Cluster w/Tach "Recontented" Foggies
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 93 |
thank you
Posts: 4,983 |
Yeah, thanks! I figured the wires were there (why would ford use two separate guage wiring harnesses)
------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX PIAA 9006/H3 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps Sidemarkers DRL Relay Maxxis UA603 205/60HR15 tires No performance mods yet!
Posts: 3,774 |
i haven't had a chance to take the dash apart again, but i will def do it by next weekend. i want to get my tach in there soon.
ok?
------------------ 1995 GL Zetec MTX...Light Blue Born: July 1995 Purchased: November 1997 KKM Intake Superchip ASP Underdrive Pulley AR 16x7.5 w/ Dunlop W-10 (205.50.16) Viper 500+ Alarm Sounds by: Pioneer CD/Polk dB/MTX Subs/Alpine Amp Richbrook Shift Knob "Recontented" Factory Instrument Cluster w/Tach "Recontented" Foggies
Posts: 3,774 |
if you are looking at the BACK of the instrument cluster, you will see two wiring harnesses. a black one on the left (passenger side) and a white one on the right (driver's side). the white harness has all of the signals fr the tach and for most of the lights on the inst cluster. the signal or the tach should be Pin #8. which is the 8th pin up from the bottom of the harness. you can get power and ground from either the black or the white harnesses by tracing where the power and ground wires are for each guage pod.
hope this helps.
Posts: 884 |
Mine's the white wire w/black stripe behind the instrument panel. HTH John
Posts: 242 |
Why not just get a cluster with the tach from a V6? Should plug in, same transmissions are used. At least one Mystique person I've seen posting has a cluster with tach in a Zetec car, and in Australia they have a tach for the Zetec.
2 Red Tours! '96 GL V6 ATX - the wifes ride '98 SVT with both options - my toy! OF's TH fix / K&N / Glove Box Light / an dats it!
2 Red Tours! '96 GL V6 ATX - the wifes ride '98 SVT with both options - my toy! K&N / Glove Box Light / an dats it!
