NOS is cheating...
I ported out the primaries with a Dremel tool and a bunch of sanding drums. To gut them I drilled a hole in the bottom of the front one about 1/2" big, stuck some long metal rods in there and hit them with a hammer repeatedly. You need to get ALL the stuff out of there- not just the cat material but the steel wool bands and the felt type stuff as well..I used a flashlight to make sure I got everything. Then I had a friend of mine weld the hole shut which only took 1 min...
You only need to port out the front one as they weld on the inside- the rear one is welded on the outside and it's OK from the factory.
Let me know if you have any other questions...
