Ok I am sure you are wounder what I am Talking About,Well I am Refering to my new ram air set up.
I had the left front fender Louverd to take in air
then hooked in some flex tubing from the fender to the air box, man it really sucks hard. So hard that when you put your hand over the louvers it sucks in your hand to the fender.
Here is where I need your help I am sure when it rains I will be pulling in water.The way I set this up it's sealed at both ends very tight, no air leaks. I did put in some screen at the fendr side but other than that that's it,then to the air box with filter.
What do you guys think ?
Thanks Rick
P.S.Did you ever get the info: I e-mailed you on how to add stuff to the Colo site, if not I can try again it will not take up any space on your hard drive at all It just some uses codes and such.
