I
I
Is there any problem going 5-20 miles without the y-pipe installed?
If its not raining, no dusty and such.
How about driving around with just the y-pipe without the pipe and exhaust?
98 Contour LX V6 Mtx
Bring your earplugs! I ran at the track after a mishap with my y-pipe and it was LOUD LOUD LOUD!
Oh yeah, it will be really loud. Just turn the radio up and pray that you don't get pulled over. wink I even got on the highway (4 miles) to get to an exahsut place. Its really loud at 80mph! smile
Chris
NJ
98.5 SVT Silver Frost w/Frankentrans
carsla AT optonline DOT net
O
O
you have to be careful of exhuast leaking into the car as well. at speed this isn't an issue, but at lights and idle the gasses can build up under the car and leak into the passenger compartment... no good! eek
this is why most states have laws where the exhaust has to exit outside the perimeter of the car...
but it should be okay for a few miles, leave the windows open to get fresh air...
Please: put something meaningful in your post subject! NOT "please readme!".
"your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes:
Silver Frost non-E1 SVT/Contour
see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
E
E
Huh... ever hear a valve pop?
When your exhaust valves operate they get RED hot... when nice cold ambient crawls up that short pipe and hits that red hot valve...
POP.
Thats half the reason we have long tail pipes... the other half is fumes.
Stock manifolds with pre-cats will adequately allow the exhaust gas to flow away and help to keep cool air from entering.
2000 SVT #674 - Check it out!
I
I
What about with the mystery mod?
if you still have the pipes from the manifolds down past the cats you are fine, there should be no worry about cold air backflowing up the the exhaust valves.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
POP.
Not to be a herk, but that's a load of BULL! :rolleyes:
If that were the case, then Nitrous would "POP" every valve the first time you sprayed, that stuff is ice cold when it enters the combustion chamber!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
