All intake systems that work on an SVT will work on your SE with no problem.
Some people with the SCA Cold Air have reported problems with idle and stalling. This is due to the relocation of the MAF that is required with the intake. The MAF is very sensitive apparently, so placing it at an angle or near a bend can mess up the readings it sends to your computer. Some people just play with the MAF placement till it works, but that does not work for everyone. Also, their intake puts the filter right behind the very warm transmission and very close to the ground, which is not cool (pardon the pun) if you go thru a big puddle of water.
I would recomend a KKM or similar filter with a Miks Heatshield, make by our own JC-Aimhigher. It might not look as cool, but I bet you it works better, and it sounds real nice
