Welcome Pat.
I do all of the work myself but I'm in Colorado Springs.
The port for the pre OBDII systems is under the hood on the driver's side near the firewall/strut tower...IIRC
You've probably got a bad O2 sensor upstream. More than likely the primary #1 bank. It's the one closest to the engine. They're notorious for causing the problems. The code reader will tell you for sure.
The chrome strips on the front were taking off in 96 but the rear remained until 97. They then went with a different rear-end which is remained until the demise of our cars. In 98 they re-did the front end and that remained until the demise. I'd suggest just having the strip painted. Either remove it yourself by taking off the front bumper and getting at the tabs that hold the strip on and do it yourself, or take it to a shop.
HTH
John
[This message has been edited by jc-aimhigher (edited April 09, 2001).]
