Posts: 16 |
I have a set of Bridgestone 225/35-18 S-03's on 18x7.5 Alba Blaze rims on my SVT with stock suspension. I have only occassionally heard rubbing from the rear on big bumps and in front at close to full lock. I pulled the front wheels off last week to put on new set of EBC rotors (@#$%& cheap Ford rotors!) and found that the inside tread section on the tires have been worn away looking like they are rubbing. What could be causing this? If not 225/35 what size tires should I be running on these rims?
Thanks,
Martin
99 Silver Frost SVT
#1060 of 2760
New 2000 engine at 25K thanks to Ford 18x7.5 Alba Blaze rims 225/35x18 Bridgestone Potenza S-03 Pole Position tires EBC Sports brake rotors in front EBC GreenStuff at all 4 corners Pioneer DEH-P3000 AM/FM/CD Pioneer TS-A6813 all around JC Whitney Diamond Blue 65W low-beams Sylvania 885 50W fogs DRLs
Posts: 536 |
Maybe a 215?? What offset are the wheels..I'm running 225/40/18 with eibach suspension and haven't rubbed at all...
Brian 1999 Contour SVT Green KKM, Dual 40 Series Flowmasters, SHO Shop Y Pipe, Removed Resonator, B&M Edge Shifter, Stainless Grills, Painted Rear Reflector, Green Underbody Neons, JSP Grand Touring Spoiler, Eibach Suspension, 18" Katana Tezzas, Pirelli Rubber, Graphics by http://www.clubconceptz.com brian8064@hotmail.com
Posts: 378 |
You could try 215/40R18 I suppose.
There are a few things that could cause your tire to wear on the inside more...but if you are sure there is rubbing just do a search and you'll find pics of where to hammer with the rubber.
